We have a RCA TV model M50WH92S. Recently it has started having the picture turn off after the TV has been on a minute or two. Then the picture will return at full intensity after a short while (maybe a minute). The sound stays on during the whole time unaltered. When the picture goes off there is a click at the back of the TV (I think it is from the right side, if you are facing the front of the TV)and it will click again when the picture returns. It keeps repeating the off-on cycle with the clicks. The click slightly (2 or 3 seconds) follows the disappearance of the picture and slightly precedes the return. The TV is just over a year old (made on Oct of 2007).
  • dwilcox Jan 07, 2009
    We had the TV unplugged for days and it still does the same thing. Also, I have a hard time believing it is the solder joints because it worked well for a year, then suddenly quit. I will check it out, however.
    dwilcox
    Scholar:
  • 86 Answers
Hi!
It is still best to have it checked personally by a technician in your area.
It's hard to speculate honestly wherein you can't get your hands on the issue.
A lot of manual testing should be done to check ICs and all.
Even if it is only a year old, poor workmanship or poor quality of the unit could cause it to breakdown prematurely.
Thanks and Good luck! =)
Posted on Jan 05, 2009
  • 679 Answers
Its more expansive to fix your problem better purchase a new.
or service need replacement of lamp as welcomejee says.
Thanks for using FixYa.
  • rockfixya
    rockfixya Jan 07, 2009
  • 10,594 Answers
Lamp seems weaker and require replacement.
    Sergeant:
    Scholar:
  • 199 Answers
Its a problem of inter board getting overheated due to any of the component getting faulty on the main board and need to be checked and replaced.
    Genius:
  • 1,199 Answers
This sounds to me like the flyback transformer is going out and will need replaced...The part is around $70.00 but it is a high voltage holder and will have to be done by a pro (this is a very common problem with this set!)
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
The problem is due to bad soldering joints in your tv .
I have an RCA M50WH92S and when i turn it on the power light flashes 5 times and no picture. I have replaced the bulb today. any ideas?
first is parts for this set can get expensive---I would do two things first:
1. Look to see if lamp comes on at all--even for a few seconds.
2. Look with lamp removed where it faces to see if color wheel broken/shattered or missing pieces of the wheel.
If the lamp does not come on the next suspect would be the Ballast which powers the lamp---if its bad you may or may not get sound either.
Dec 09, 2012 | RCA M50WH92S Bulb
RCA 50 inch M50WH92S has
You should suspect damage inside the optical light engine the set uses.
Jun 16, 2012 | RCA Televison & Video
My rca tv m50wh92s turns off and on by itself on wont stay on long
Try to unplug the set for a while and plug back and confirm actual model number to me.
Mar 12, 2012 | Televison & Video
RCA M50WH92S PICTURE COMES ON FOR ABOUT TEN
Replace your LAMP if all of your Fans are running! If lamp fan is not running Lamp will not turn on .Call FOX for Lamp 1-800-227-5369
Jun 20, 2011 | RCA Televison & Video
Rca 50'' dlp model # M50WH92S turns off, light blinks 3 times
Dec 25, 2009 | RCA Televison & Video
Problem with TV turning on and off sound remains on though
Changing the lamp is easy enough. The lamp is about $250.00 . There's a lamp cover door usually in the back that removes, then the lamp housing will be displayed held in with 2 screws most of the time,, then you will be able to pull the lamp assembly out.
Feb 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca m50wh92s dlp projection tv
it is the lamp...easy fix
Jul 07, 2008 | Televison & Video
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Picture turns on and off
Just found this trying to figure out what was wrong with my same model tv. Since mine was under warantee, I had the repairman troubleshoot it. He changed the lamp and the tv started working normally again.
I didn't understand how the lamp could be bad if it lit up while the tv was on. He said the tube was probably using too much voltage or too little voltage to run, so the tv would turn itself off and on in an attempt to receive the correct voltage from the lamp.
I realize this is 9 months late, but maybe it can help someone else who has this problem. I can't believe there are only 3 rca dlp's out there with this problem.
Mar 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
