How do I establish my wireless connection? - Computers & Internet
  • 826 Answers
Follow this link to setup your wireless connection help:
http://www.microsoft.com/athome/organization/wirelesssetup.aspx#fbid=-LHvpGzPALj
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Nov 08, 2012
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Where do I fine SSID Name & Encryption Key
If you are trying to set up a router and need to establish the SSID name and WPA encryption key, you will need to sign into the router using the routers IP address. Input the userid and password, then go to the wireless network setup page. Here is where you enable wireless operation, establish the SSID, and generate the encryption key or passphrase.
If you are trying to connect to someone else's wireless network, you need to know their SSID so that when you do a search for available networks you can determine which is theirs. Once that is established, if they give you the encryption key or passphrase, you can attempt to connect to their network. With the encryption key or passphrase, you will not be able to connect.
Mar 15, 2015 | Motorola Computers & Internet
How do i fix EHRPD 4 unable to establish wireless data connection
Do you try to use one of your own wireless routers? If not, I know what is wrong. You should install a wireless router yourself.
If you have a wireless router, you are the one to setup the security and you have to know how to log in to the router. Because you chose the login name and the password in the first place.
Jul 17, 2014 | Samsung Galaxy S3 III I9305 LTE Unlocked...
What does "wps" mean?
WPS is wifi protected set up.
It is advanced feature available on wireless routers and wireless devices
it is available as button
when a user wants to establish connection , he needs to press the WPS Button on the router and then on the wireless device he wishes to connect to establish connection
this feature is for wireless security purposes
Aug 06, 2013 | Computers & Internet
The keyboard doesn't work, even though I just changed the batteries. Now what?
>when wireless keyboard or mouse runs out of battery, you need to re-establish the bluetooth connection in order for them to be functional again. To do so, you need to press the connect button on the keyboard and the USB dongle connected to the computer at the same time for about 8-10 seconds to establish connection. After that, you can try typing again. Same thing applies to wireless mouse.
Oct 03, 2010 | Gear Head WIRELESS keyboard/Mouse
I dont know my wpa key to get online
Use an Ethernet cable between the network-port on your computer and one of the LAN ports on your wireless router.
Start Internet Explorer.
Connect to the web-server "inside" the router.
Run the "Wireless Networking Setup Wizard", to establish an SSID, choose an encryption-level (use 'WPA'), and to establish a password/pass-phrase/network-key.
Use the SSID and the password to connect to your newly-configured wireless network.
Sep 24, 2010 | Computers & Internet
My wireless connections will not work! last night both lap tops and my daughters zip it were unable to establish a wireless connection. It happened once before about a month ago and were able to...
OK, to clarify.
Ethernet = modem?
Wireless box = router?
Do you have hardwire connection to router?
Check the wireless settings in router with hardwire connection.
Most routers use random channel search for wireless.
I usually set this for to use one channel only.
Stops random interference and connections.
FYI: Most routers are on 2.4ghz - same as cordless phones and some hand radios - the frequencies over lap sometimes - even though they aren't supposed to.
Microwaves will also disrupt signals.
Apr 04, 2010 | Computers & Internet
Attempting to connect WGT624 V4 as a wireless bridge to connect to my 2 wire qwest dsl modem to connect tv components to internet along with Xbox 360
To establish the bridge connection, make sure to write down the Wireless MAC Address of the 2wire first. Now login to your Netgear router's setup page and go to the wireless bridge settings. Manually type there the Wireless MAC Address of the two wire. Make sure to enter the same SSID, same Channel and same Wireless Security Key to successfully establish the wireless bridging. Save your settings after that and reboot the router.
Oct 22, 2009 | Computers & Internet
THE internet is coming up internet explorer can not be connected, when it's wireless. we can plug it in and then the internet comes up.
you have to configure your wireless modem (wep/wpa) so that your laptop can connect to the internet. the reason why you cannot connect in the internet thru wireless is that the connection between the modem and the laptop has not been established. so, try to establish the connection between your laptop and the modem.
Apr 01, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
