Question about Canon Office Equipment & Supplies
Paper not feeding in canon mp497 printer
The paper only goes in partially and it cannot print
  • 826 Answers
Usually this is caused by a tiny sliver or scrap of paper caught somewhere in the paper path.
First, check for paper stuck in the feed rolls. If you cant find anything causing it, its time to scrap it out. It would cost more than a new printer to fix it.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Nov 08, 2012
SOURCE: Lexmark X73 print/paper problem
Same problem here. Went thru a few tests with Lexmark but didnt help. They next said it would be best to get new one since repair cost would be higher. Thru front door I do see a spring that moves freely. That must be broke. After their help they sent email for 20% off.
Posted on Sep 13, 2007
SOURCE: R1800 printer problem
I fixed the problem, the PW and Ink Mark sensors needed cleaning. I was able to access and remove both sensors after removing the printer housing, and moving the print head to the far left. There's enough space to unscrew the cover for the sensors, and unplug them with needle nose pliers and a couple fingers, clean them both, dry them, re-install, etc.. all is well now after some re-alignment procedures with the epson factory service program.
Posted on Feb 15, 2008
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
The paper feed is screwed up. We tried printing on paper that had already been fed through the printer and a piece got stuck. We think we got that all out but can't be sure b/c we don't know how to fully...
The chances are you have a piece of paper blocking the paper path.
Try tipping the printer with the paper input upside down to see if your can dislodge the offending piece of paper.
Next, try taking a thick piece of paper (double weight or construction paper) and feeding it through to see if you can push the offending piece of paper out.
If these do not clear the problem, let me know and we can look at partially disassembling the printer to clear the path.
Please rate this solution. Thanks.
Aug 30, 2010 | Canon MX700 Office All-In-One InkJet...
PRINTER SAYS 'PAPER EMPTY/ LOAD PAPER' -- BUT SHELF IS FULL. WILL NOT PRINT/ FEED PAPER
IP4700 series has 2-way paper feeding. Please check you paper feeding from bottom cassette or rear auto feed!
Before perform the printing job, you may notice on your printer right side can select paper feed from rear or bottom.
Enjoy printing.
May 29, 2010 | Canon iP4700 InkJet Photo Printer
Paper feed problem- am i best off replacing
If it was feeding paper askew, I would have thought the paper track may be partially blocked. A bit of paper of debris of some sort blocking a smooth run of the paper.
Having had a real good look, see if it can find anything, the next thing I try is passing a sheet of heavy gauge paper or card maybe, to see if that clears the track. Most printers have a paper feed function which bypasses printing a document.
Mar 23, 2010 | Canon PIXMA iP90 Mobile Printer
Starts to feed paper and then stops and says it is jammed, it's not.
We have become aware of an incompatibility between the ZoomAlbum software and the Canon PIXMA printers listed below. This issue applies only when using the ZoomAlbum software to print Photo Album covers with Mac OS X.
Affected Models
PIXMA MP240, MP250, MP480, MP490, MP560, MP620, MP640, MP980, MP990, MX320, MX330, MX860, iP3600, iP4600, iP4700 Printers
Phenomenon
The affected PIXMA printers are designed to feed paper via the rear tray with a center-feed mechanism and two paper guides. However, the ZoomAlbum software was intended to feed paper from the rear tray in printers with a right-feed mechanism and a single paper guide. As a result, when using the ZoomAlbum software with Mac OS X to print Photo Album covers with the affected Canon PIXMA printers, the printed image may shift.
adv_zoomalbum_1.jpg Countermeasure
To remedy this problem, please use the following settings when printing Photo Album covers with Mac OS X:
1. Click System Preferences
2. Click Print & Fax
3. Select your Canon PIXMA printer as the default printer
4. Select DL Envelope for Default Paper Size in Page Setup
Note: Be sure to change the Default Paper Size back to Letter after printing the cover.
Jan 26, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Bubble Jet printer won't feed paper and print properly.
Hello sir; You need to clean up paper pick up roller and feed roller with alcohol, if still have problem then replace it.
Nov 07, 2009 | Canon BJC-85 InkJet Printer
Won't print
The roller that feeds the paper is probably dirty. you can carefully clean it using platten cleaner, rubber conditioner, or alcohol in a pinch (it will dry the rubber out with prolonged use.)
Dust is the usual cost, but glazing of the surface from a lot of use is also common.
Aug 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Printer is not feeding the paper through but acts as though it is printing
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-7
Apr 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer misfeeds
1. Unplug the printer power cord and remove the back door.
2. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around.
3. Allow the rollers to dry completely, then close the rear door.
4. Open the print carriage access door.
5. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. Do not lubricate the rod.
6. Close the printer, plug the power cord in, and turn on the printer power.
Ensure that you select appropriate paper type and size before printing.
Thank you
Dec 19, 2007 | HP PSC 1510 All-In-One InkJet Printer
107 people viewed this question
old marine
old marine
