Question about Maytag Neptune MAH5500B Front Load Washer
The water will not go into tub, keeps overflowing and flooding my laundry room
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If the water will stop filling when you stop the machine, then you need to replace the "pressure switch" on the unit. Here is the part to order.
If you have to turn the water off at the faucet to get it to stop filling, then you need to replace the "water inlet valve" on the unit. Here is that part to order.
Posted on Nov 09, 2012
  • 1028 Answers
SOURCE: Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Posted on Apr 27, 2008
fredcause
  • 51 Answers
SOURCE: Hi, I have a Maytag
the water level sensor is defective and need to be replaced
Posted on Dec 08, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: Won't shut off machine turns off after a few seconds
You may have a burnt motor. This is usually caused by a clog in the pump. Sometimes small items such as socks find its way to the pump. It could also be the timer itself. If there is a burning smell when that happend it is probably the motor.
Posted on Jun 28, 2009
  • 239 Answers
SOURCE: My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Posted on Apr 23, 2010
FAV6800AWDIY
  • 526 Answers
SOURCE: filled with water and won't drain
You’re in the FAV6800a/FAV9800A forum so I’ll assume it’s one of those models. You can do this from Service Mode the method I prefer less messy, just follow this process it’s in the SM but I typed out for ya.
To pump out the excess tub water while failing to complete spin cycle.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with the off button or hit the Presoak key.
Sorry to hear about the over fill. May be you have a stuck water valve or stuck pressure switch. If you want some help just verify the Model type…..Rich
The Service Manual for reference. Sears Parts Direct for reference.
Posted on Apr 25, 2010
My LG Trom front loader washer the water will not stop coming into the tub until the door pops open and floods my laundry room. How can this be fixed?
most likely a bad water pressure sensor or a plugged tube. check repairclinic.com or appliancepartspros.com for info, videos that show you how to fix.
Jul 14, 2015 | LG Washing Machines
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Gene
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
Tub overflowing with water,
sounds like the plastic tube that goes to your water level switch has come off,,,, mine fell off and flooded the kitchen and had to put a small clamp on it!
May 14, 2010 | Washing Machines
Apr 22, 2010 | Maytag Performa PAV2200
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Water was overflowing over the top and flooding the laundry room
If it was left in the reset position then it could absolutely pushed the diaphragm in the air switch to a point that the contactor couldn't reach it. Set it on a large load, let it fill and watch it. If it starts to overflow, pull the plug out, if it continues filling, you need a new water valve on the washing machine and if it stops then you need a new level switch
Jun 16, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Washer Tub Fills With Water When Washer is Not On
dtfpaf, you need to replace the water inlet valve. Easy job, post the model number and we'll get you a part number...Catriver post back.
Jan 20, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
