Question about Proscan PS50700 50" Rear Projection Television
How do I fix a convergence problem on a Proscan 50
Image looks like if a 3D or gosthly
    New Friend:
I dont know how to fix it, only had the tv for 3 months already having problems doesnt say much for proscan!!
Posted on Mar 08, 2013
Image is double like ghosts with a greenish/redish color
Not a lamp as this model (one listed) uses 3 picture tubes--likely a convergence problem--see typical in attached photo.
This set does but rarely have this problem---take a careful look on back where model number is at and look for chassis number--is it a PTK195 or what? That chassis had one easy fix for this problem.
Nov 08, 2012 | Proscan PS50700 50" Rear Projection...
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Image is out of focus. colors do not align
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
9e1b49a.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jan 14, 2010 | Zenith R50W46 50" Rear Projection...
I just bought a used HCN4226wx/xaa, the green and
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Picture looks like it is 3D
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jul 17, 2009 | Proscan PS61670 61" Rear Projection...
60pp9363h/17
You have a convergence problem.  Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors.  Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors,  etc. Everything you need to fix it yourself.  Its an easy fix.
Sep 28, 2008 | Philips 46PP9302 46" Rear Projection...
Proscan PS50700 Convergence Problem
  • Screen looks 3D
Nov 09, 2007 | Proscan PS50700 50" Rear Projection...
Blurry - Looks like 3d
THE PROBLEM IT'S THE CONVERGENCES STK.
Nov 01, 2007 | Proscan PS56670 56" Rear Projection...
Proscan PS50700 50" Rear Projection Television Logo
71 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
