Question about Crosley CDE6000 Electric Dryer
Crosley heavy duty giant capacity plus auto dry control wont dry
Warmed up at first but will not dry my mothers clothes. Please help her, she can't find the model number and the only electric dryer product option is listed below. If it is the heating coil? can you tell us where to find another one and if able to fix ourselves?? Please send response to both emails so my little brother may assist my mother if I am unable. Thanks and Happy New Year!
jkvarmstrong@yahoo.com; greekbroncos@aol.com
  • Crosley Master
  • 8,220 Answers
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Posted on Jan 13, 2009
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Where is the heating element on a crosley heavy duty giant capacity plus
The element will be at the back of the dryer behind the drum I will give you a link to a video that will show you how to do this .It is not a hard fix and takes 15 to 20 minutes..
Jul 04, 2012 | Crosley Dryers
It takes at least 2 cycles to dry clothes. It is Roper heavy duty high capacity electric dryer. Thank you for any help you can give me. janebellard@yahoo.com
Check for air restrictions which cause the heat control to shut down faster than normal.
When the moisture cannot be removed fast enough the heat builds up and has nowhere to go so the heat control stays off longer and the clothes just tumble on.
Service manual and more HERE
Mar 14, 2011 | Roper Dryers
We took our heating element out of our dryer and didn't mark the wires. Is there somewhere I can download a map of where the wires go? It's a Crosley heavy duty giant capacity.
How many wires do you have? If only two, the heater element doesn't care which wire is attached since it is being fed with AC current there is no polarity to it.
Oct 29, 2009 | Crosley CDE6000 Electric Dryer
Does not dry clothes
If its not heating up correctly you could have a bad thermostat, blocked up vent or dirty lint screen, or possible the coils that go near the ignitor need replacing.
Sep 21, 2009 | Dryers
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
My washing machine won't spin!
as with basic spin faults -a number of reasons usually 1 motor brushes, 2 motor 3 motor control pcb or the obvious one - the belt has come off.
Mar 13, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Final spin drum knocks and is unbalanced, never used to do this.
Hello, if your clothing are sorted imbalanced you will have that problem. Ensure they are evenly distributed.
If that doesnt solve the problem, there is a bolt that is broken on the agitator shaft. Lift out the top cap from the agitator, take out the plastic seal beneath, remove the bolt, lift agitator out.
There are two horizontal bolts holding the inner-drum to the shaft. replace both.Be sure to tighten all the way.
May 31, 2008 | Hoover Nextra HNT 2135 Top Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Crosley CDE6000 Electric Dryer Logo
567 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
