Question about Canon PIXMA MP780 All-In-One InkJet Printer
Expert required asap please!! MP780 I need to print a 10 page Word Publisher document to A5 size for a brochure. I hope to be using a Cannon Pixma MP780 tomorrow. My question is can I print 2 sides/pages on one horizontally using the automatic duplex funtion? Is it big enough to have a horzontal feed? (aint seen one yet!) I have tried using a ip4300 today but the pages do not all face the same way up...I dont fancy standing by the machine to do 500+ copies manually...ouch. Any clues much appreciated! Magda x
    President:
  • 8,637 Answers
The ip4300 will do duplex but you have to in and put a check mark by the DUPLEX to get both sides to print. Also make sure you select BOOKLET PRINTING so the page layout is back to back so it can be reead like a book as you flip the pages. Hope this helps. Bud
Posted on Jan 07, 2009
Canon ip3600...printing from micro soft publisher it reverts to default paper size A4. How to correct this.
Select what you wish to print, go to printer settings, select paper size and the print.
Dec 09, 2017 | Canon Office Equipment & Supplies
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
Printing from my HP laptop all the printers will only print A5 size not fit to page A4. Have another computer and printers will print fit to page A$
Have you checked the printer settings when you get the print screen?
Most likely it is set up for A5. That or the page layout of the document is set for A5.
Feb 21, 2015 | HP Pavilion Computers & Internet
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
I can print a computer document in the canon pixma mp780 but I am unable to make a copy, come out blank. What is the problem?
For copy, first u need to scan a document. save it in ur desired format. then print it. give necessary instructions in scan & print settings. color/black&white, dpi, page sizes etc. etc.
Sep 04, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do i set the cannon mp780 printer to print on leagal size paper
file:///C:/Documents%20and%20Settings/GX-620/Desktop/PIXMA_MP780_750_UG_Win_EN/Output/Chap10_US.htm
copy and paste the URL
And when that opens go all the way to the very bottom of the page and you'll see PAGE SETUP in the picture you can see where to change paper size...
May 15, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Pamphlet on microsoft publisher
There is a template you can download from microsoft for either Word or Publisher. You select new, then templates, and select the Brochures category. They will have the layout for the pages and colums for back-to-back printing for tri-fold brochures. Just select the style you like and download it. The templates may already be installed with Publisher.
Apr 12, 2009 | Microsoft Office Standard for PC
To fix the page layout to
Oomar,
Using Word with VB6, I show how you set the page size to A5:
Sub AutomateWord()
' Declare the variable.
Dim objWD As Word.Application
' Set the variable (runs new instance of Word.)
Set objWD = CreateObject("Word.Application")
' Add a new document.
objWD.Documents.Add
' Add some text.
objWD.Selection.TypeText "This is some text."
'Set Page Size
objWD.ActiveDocument.PageSetup.PaperSize = wdPaperA5
' Save the document.
objWD.ActiveDocument.SaveAs FileName:="mydoc.doc"
' Quit Word.
objWD.Quit
' Clear the variable from memory.
Set objWD = Nothing
End Sub
Hope this helps!
Mar 18, 2008 | Computers & Internet
Printing 2 pages on landscape document
Usually if you see the page in the Publisher window is already landscape, it will go landscape in the Printpreview and also in the print out. I just try to imagine what is your problem.
If I am not mistaken, this is what you did:
You have two "small" pages (maybe A5??) and you want to print it in one page of A4. Of course the A4 should be landscape.
Publisher does not have the facility to set 2 pages A5 in one A4 like in Microsoft Word.
The easiest way is just create a new page with A4, then copy the 2 pages (or you called it flyers) and paste it in that A4 landscape page.
Publisher can do print 2 pages A5 in one sheet A4 but the arrangement is as booklet. You can see the choices in File --> Page Setup --> tab "Layout" --> scroll the Publication type.
I do print 2 pages A5 in one sheet with many variations using addition software named "Clickbook".
Let me know if I m wrong in interpret your problem.
Feb 10, 2008 | Adobe Photoshop 7.0 for PC
Lost reverse side printing option
Yepperz
The double sided printing option relies on Status monitor working correctly. If information cannot travel from the printer to the computer, the option will be greyed out.
Make sure you have a direct connection to the computer without any hubs. If that doesn't work, try the following.
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Sep 07, 2007 | Epson Stylus R265 InkJet Photo Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
