Question about IBM 11L1619 Motherboard
I B M 300pl mother board boot problem
When my computer start it says that system is lock and turne off power then turne on power your system isd lock can any one tell me how to unlock the system i cant go to bios configeration tooo
  • umesh Dayal May 29, 2007
    Thanks but it dint solve the problem
    well when my computer starte (it a I B M 300PL 500 mz P111 )
    the mother board strt it dosent go the bIOS but this masage apeya
    161-bad cmos batery
    the RF-ID Tag has change
    184 assent control not detected
    system securut\rty-keyborad is locked
    system securetyikey boiard is unlock
    the system securety assent controal has been violated
    turn power to your system off-and turen on
    your system is now lock
    thios apeya what can i dothe make it work sory bout my english
    thank you
    umesh
  • Anonymous Apr 09, 2009
    I'we got the same problem. Any help pls?
  • 4 Answers
Yes you will not be abble to do anything until you remove the protection code which someone activate it. Try to remove the battery on the motherboard and then boot the computer.
Posted on May 23, 2007
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
I have an Intel E210882 mother board. Within a week, it was starting to become hard to boot, then I had to boot in F8 mode, and now when I turn on the power switch, the LEDs light turn on and the cpu fan...
If you have another computer that will hook up to the internet, download a copy of any live Linux CD (UBUNTU) and see if the computer will boot with that (you download a image file that burns to a boot able cd). If it will boot with a live CD, then you have a Hard drive / operating system problem. If it will not boot from that, you have a mother board problem. Start removing things from the motherboard, unplug and remove everything then plug hook up things one at a time.
Sep 18, 2010 | Intel Motherboard
When i start my 300pl desk top system. when i
Hello my friend.That error message has nothing to do with the actual keyboard.The POST/BIOS is reading a single port bit in the system boards keyboard controller and detecting this bit as being shorted to ground. On some systems there is a keylock on the front of the case that allows you to "lock" the keyboard for security reasons. It is this lock that is being detected. On a system without a keylock, this error can be caused by one of the front panel wires being placed on the wrong pin on the system board. Or by something shorting out the keylock pin on the system board, or a hardware failure in the keyboard controller, or using the wrong version of BIOS.So make sure if your computer has a lock key/button or something on the case that locks the keyboard.Also you can load default bios settings by hitting Del while you boot if you have change anything in the bios.
Feb 08, 2010 | IBM 300PL (PC 300 PL 733) PC Desktop
No hardware was changed, but just one morning the system was powered on and came up with these error messages the RF-ID Tag has changed 184 Asset Control Antenna not detected System-Security Keyboard is...
It seems that the CMOS Battery is creating a problem. See this link for reference. Also, you can get into the BIOS utility, load the defaults and then try to boot your computer again.
May 14, 2009 | IBM 300PL (PC 300 PL 733) PC Desktop
System not booting
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-23
Feb 03, 2009 | Mercury P4VM800M7 Motherboard
IBM 300PL Model: 6862-V20 Booting Sequence cleared problem
boot in bios and reset the intrusion to read and clear it out alot of times the bios will use its backup when cleared clear the ir setting as weel and remove any passwords in the security setting in the bios if you are using a pov card you may have to take it and reset the machine then disable the card funtion reinstall then reset the card from there
Dec 19, 2008 | IBM LENOVO VIDEO CARD 3D PRO 4210 00N3439...
My 500mz IBM 300pl computer is giving me this masage i cant tart the computer
Install a new CMOS battery. Go to walgreens, walmart, something and buy a new one. This is located on the motherboard. Following this, you may need to flash the bios, and reinstall with a newer updated version.
May 29, 2007 | IBM 11L1619 Motherboard
IBM 11L1619 Motherboard Logo
440 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
