WATER DOES NOT TAKEN AND SPIN NOY WORKING - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 09, 2012
The problem with xqb90-701 machine comes up with e2 code will noy rinse ,empty or spin
I don't know what the codes are for this washer but it sounds like it has to do with the pump not coming on and pumping out the water. most of these front loaders have a clean out for the pump filter you should find it between the pump and where the drain hooks up to the tub. many times they get clogged with stuff. I worked on a whirlpool the other day that had a large sock stuck in it.
May 09, 2014 | Washing Machines
Krystal clear model 633 hums but impeller does noy spin
Starter winding or cap or switch has failed. Unplug. Look for broken/loose wires or burned components, if you can't find anything you will have to replace the motor. If that is not possible, replace the entire unit.
Sep 20, 2012 | Intex 2500 GPH Filter Pump Krystal Clear...
Kitchenaid stylemaster no.622768
spin cycle does not work. Load was overloaded and refused to spin.
have emptied water, taken off lid, does not appear to be limit switch.
HELP
Feb 20, 2012 | KitchenAid Washing Machines
Will not spin out water
the machine does not spin out the water,once the spin starts it sends a signal to the water pump ,so it comes on and starts pumping.So now we should ask why is the pump not working?1 and most likly cause is something stuck down in the pump,i have taken socks out of them before, 2 but if its all clear then i would suspect the pump itself.its going to have to be a engineer to look at it,unless you could repair it yourself?.adrian,,,,,,,
Aug 25, 2010 | Frigidaire Affinity ATF7000E Front Load...
Wash but not spin cyecle
Check whether the water drain taken place. if all the water drained, the spin will start. A little spin action first and full spin later. ( depends on the program design)
even after drain there is no spin, it could be water level zero not sensed or timer/micro controller needs to be checked
Apr 01, 2010 | Kenmore Elite 45986 Front Load Washer
120v plugged into 220v outlet
Thata agood question maybe the motor and maybe a lot more like the water valve. the agitate and spin selonids and the timer. Cant say cause some of them may noy be out.
May 10, 2009 | Washing Machines
Washingmachine
try unplugging for 10 minutes as this resets the board and try again please come back if this does noy work
Jun 22, 2008 | Hotpoint Ultima WF860 Front Load Washer
Candy nova not spinning / drying - i unclogged filter but still not working - there is power but the machine just sits there.
It sounds like a motor problem poss the brushes are worn alot of people asume, because the drum is noy going round that the washer is sticking. Or poss the drive belt as come off. Good luck
Mar 04, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
