SPIN NOT WORKING AND WATER DID NOT TAKEN - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
Kitchenaid stylemaster no.622768
spin cycle does not work. Load was overloaded and refused to spin.
have emptied water, taken off lid, does not appear to be limit switch.
HELP
Feb 20, 2012 | KitchenAid Washing Machines
Will not spin out water
the machine does not spin out the water,once the spin starts it sends a signal to the water pump ,so it comes on and starts pumping.So now we should ask why is the pump not working?1 and most likly cause is something stuck down in the pump,i have taken socks out of them before, 2 but if its all clear then i would suspect the pump itself.its going to have to be a engineer to look at it,unless you could repair it yourself?.adrian,,,,,,,
Aug 25, 2010 | Frigidaire Affinity ATF7000E Front Load...
Wash but not spin cyecle
Check whether the water drain taken place. if all the water drained, the spin will start. A little spin action first and full spin later. ( depends on the program design)
even after drain there is no spin, it could be water level zero not sensed or timer/micro controller needs to be checked
Apr 01, 2010 | Kenmore Elite 45986 Front Load Washer
The top water spray fan is not spinning but water is flowing thru it. I have taken it apart and cleaned it out. Stil nother
This sounds like a kinked water feed line. Follow the water line from the inlet pipe to the pump and look for kinks or other obstructions.
When the obstruction is removed or repaired, the water pressure will start the arms spinning again.
Feb 16, 2010 | Dishwashers
Bottom sray spinner doesn't spin. Computer and
Make sure that the spray bar when lifted by the water pressure is NOT hitting the dish rack OR has excessive friction. Test by manually lifting and turning.
Also the jets must exit at an angle to provide the torque.
Oct 20, 2009 | Amana 24 in. ADB2200AW Built-In Dishwasher
Washer does not spin
that wont cause it not to spin but it just jerks the tub around a bit stronger.you most likely have a bad clutch.you can take front panel off and see if your clutch is grabbing when you put it in spin.it is under the motor.
Mar 12, 2009 | GE WBSR3140DW Top Load Washer
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Whirlpool front loading washer
The 02 error code relates to a drain problem. Check that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Regarding the spinning noises and vibration, open washer's rear panel and look for a released or a malfunction shock absorber. Good luck!
Aug 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
