Question about Microwave Ovens
Electrolux processor model SFP 101 shows an error message and won't start
The processor hadn't been used for some time.Then when switched on it worked briefly then the "Er" message came on.No response from machine buttons.Have checked the correct installation of the bowl where it connects to the processor.
  • 8909 Answers
SOURCE: The "tube" of the bowl
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 30, 2010
  • 1833 Answers
SOURCE: GH6177 Micro Hood, Says "Mains
Your generator may be putting out a square wave as an alternative of a true sine wave. There is typically a circuit in the microwave which monitors the AC line for timing purposes, and a square wave may not be interpreted correctly. You may need to contact the manufacturer or installer.
Posted on May 05, 2011
  • 7 Answers
SOURCE: I have a built-in AEG
What fuse did you change? The fuse on the wiring that leads to the microwave needs to be intact, then the fuse in the Microwave itself needs to be checked. Usually there is a plug where the microwave is plugged in, in the cabinet above the microwave, you can take another small appliance or a power tester to make sure power is available in the outlet where the microwave is plugged in. If the power is on at the outlet then you'll know that it is the microwave itself that has turned itself off for some reason. You can get manuals for these ovens at this website
Posted on May 11, 2011
SOURCE: I have been given a
All Magimix processors I have seen have not had release buttons to release the bowl/lid. It may be worthwhile you contacting Magimix themselves to see if they can help you.
Posted on Jul 04, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: The microwave display shows "Door" and it won't
I could have been more specific with a model number, but if this general answer doesn't do the trick, feel free to contact me with your full model and specific symptoms here.
It's usually a bad door switch or door switch mount. My helpful text file on door switches is here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's one of those overdesigned Whirlpools, it can be one of many components. See the example photo at the bottom of this reply.
Posted on Oct 06, 2011
I have a frigidaire Electrolux gallery series glmv168cqi microwave. The timer counts down, but the oven doesn't turn on. Sometimes when you open the door the fan turns on.
That would be a failing bottom door switch, or its mount.
My help file on door switches is here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
There's a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Once the control panel has been removed, you can access the door switches for testing and possible replacement.
There should be a technical manual hidden behind the controller or grille, too.
If you need further part ordering help, contact Electrolux:
USA
800•944•9044
Electrolux Home Products
North America
P.O. Box 212378
Augusta, GA 30917
Canada
866•213•9397 (English)
866•294•9911 (French)
North America
6150 McLaughlin Road
Mississauga, Ontario, Canada
L5R 4C2
Apr 22, 2013 | Microwave Ovens
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
Dec 04, 2011 | Whirlpool Microwave Ovens
Microwave will not start after putting in time
here.
Emc38905x Does not start. Select microwave, then power then time press start & nothing happens. Need to toggle the power to reset & ok for afew days then fails again
I have an ELECTROLUX MICROWAVE (Model : EK23CBS4) purchased in January-12 from Pune. During usage glass plate got automatically cracked. when i called up service centre they said glass plate is not covered under warranty. When I verified the warranty book there is no as such things are mentioned. Most of the customer having the same problem glass plate getting cracked automatically. So I will suggest do not purchase any of the product Microwave Oven of ELECTROLUX. This is our responsibility avoid any product to purchase of ELECTROLUX.
Thanks, Mritunjay Kumar Cell# - 9922385632
Nov 06, 2011 | Electrolux E30MO65GSS Convection Microwave...
H98 shows on display and won't start
This error can be due to a failure in the output.Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Thank You for using FIXYA.
Aug 18, 2011 | Panasonic NN-T994SF Microwave Oven
Aug 03, 2011 | Whirlpool GT1195SH Microwave Oven
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
What does error message F5 mean?
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing..
I'm not finding the one for for this model online.
If it's a convection model, F5 would be a damper door sensing error, which is usually a bad switch.
More info on switches is here.
One of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
If it's not a convection model, F5 is probably a sensor error.
On some models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Here's some info from Samsung, which is the actual manufacturer of these ovens:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Feel free to contact me directly if you need more help.
Aug 22, 2010 | Frigidaire GLMV168K Microwave Oven
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
