Question about HP DesignJet 3800cp InkJet Printer
Printer Does Not Print.
I just bought this Printer and am in the process of setting it up. I install the drivers that come with it. In the Select Printer option i choose HP Design jet 3000cp (because 3800cp is not listed). The link below is a screen capture of the steps i am doing to install. http://www.gcsclothing.com/Install-Cap.rtf Well after i install the driver i go to print (i have the printer connected to my laptop using a parallel cable.) When i go to test print/photoshop print/MS Office Print it all does the same thing. It looks like it is going to print, a print window pops up and has a picture of my printer printing and then the little print icon appears on the task bar. Also at this time the printer status changes to receiving. Then all of a sudden the window and the icon disappear and the printer status goes back to ready and does nothing. I have tried it on two different computers but i keep getting the same result. What am i missing.
  • 1 more comment
  • George Villalobos May 23, 2007
    both computers were running Windows xp (one Home edition and one pro edition). oh and the screen shots were saved onto wordpad.
    Here is the file i had from above.. i switched it to an html page.
    http://gcsclothing.com/Files/3800.html
    on the printer properties it is clicked to LPT and in the device manager it is on the list.
    Would using a parallel to usb do anything?
    thank you. i will check out their website for drivers and e-mail their tech support.
    Genius:
  • 2,985 Answers
What are the operating systems of the computers? Have you checked that the printer is supported by these operating systems? There appear to be issues with Vista computers for driver for many peripherals Suggest you contact HP rethis one By the way your Screen shot that mode is it? I dont seem to be able to open it with the regular programs.
Posted on May 23, 2007
  • 1 more comment
  • john ash
    john ash May 23, 2007
    Screenshots are image files - usually JPEG
    Word pad is a text editor not an image editor
    I notice you say you have connected by parallel cable.
    In fact printers these days are universally USB and the XP will look for a USB connection
    So check where your printer driver is directed -
    Parallel will be LPT1
    USB will be printer USB
    Go to Start Printers faxes right click printer and then click properties to check the driver
    Go to Start /Control Panel/system/Device Manager look ay LPT and the run down the USB connection to to USB printer connexion.
  • john ash
    Image 2
  • john ash
    looks like you are doing it right- but there is perhaps a subtle difference perhaps between the correct driver and the alternative you have selected
    So it would seem the Hp are at fault.
    Check their website for river downloads and also raise this query with their Tech Support
SOURCE:
Epson TM T88iii printer not printing
Since you are using the USB-to-serial converter, you need to select the serial interface in the printer driver installation.
  1. Uninstall the driver in Control Panel > Add or remove programs
  2. Restart the computer
  3. Install the printer driver again, this time select serial in the interface list
  4. Set the properties for the serial port to 9600 for the data rate
  5. Print a test page!
Sep 07, 2017 | Epson TM-T88III Thermal Printer
Epson l100
SETTING UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer.
You need to install the printer driver on the computer and configure it as a Shared printer.
The other computers on the network need to add this printer to their computer.
Follow these steps to set-up a shared network printer -
1. Connect the printer to the computer and install the printer driver.
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click
Share this printer, and then if you wish you could change the Share name, then click OK
3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Follow these steps to configure the computers on your network :-
1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached
to another computer - Next.
2. Select Browser for a printer - Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next
4. Select Yes for - Use this printer as the default printer - Next - Finish
5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
May 07, 2013 | Computers & Internet
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I keep getting the message failed to create print object Lexmark 6500 series. The specified module could not be found. (126)
It coudl be a printer driver issue. Please follow the steps below to fix the problem.
First, uninstall your existing print driver. On your computer, go to Start menu > Programs > Lexmark 6500 Series > Tools > Uninstall. After the uninstall process, reboot pc when prompted.
Second, visit the Lexmark website to download and re-install the Lexmark X6500 printer driver. Select your operating system > download > execute the file. Follow the instructions on your computer screen.
Lastly, after the re-install process, try to print again to verify that the problem is fixed.
Sep 06, 2011 | Lexmark X6570 InkJet Printer
I dont have installer driver hp 695c
You can download a driver from the manufacturers website which is located at www.hp.com. Click on support and then download drivers/software. Enter the model number of your printer and follow the prompts to download and install the drivers. Do not connect your printer to your pc until the drivers and/or software is installed.
Jul 06, 2011 | HP DeskJet 695c InkJet Printer
Can't get the duplexor to print on both sides . The duplexor is installed, but it will not allow me to print on both sides of the paper. It will print one side then it flips to the other side and says...
Unless the driver has an 'auto-discovery' feature (not all drivers do), you would need to configure the driver to show the duplex unit as 'installed'.
On the driver Properties dialogue, select the "Device Settings" tab (may only be available when logged in with administrative rights) and change the 'duplex unit' option from "Not installed" to "Installed".
hope this works for you ,all the best.........
Mar 13, 2010 | HP LaserJet 4250n Printer
I have a Xerox 7655 printer and I am trying to use the direct print tabs. After downloading the template and following the instructions exactly, they are printing upside down and backwards. Can someone...
You may need to change the driver. I have seen different issues with machins printing tabs, that changing the print driver will solve. Most of the tab issues are when the driver is a PCL 5 or PCL 6 driver. Switching to a PS driver frequently helps resolve those issues.
The newest drivers would be located on Xerox.com. Go to the home page, select Drivers and downloads, then enter your model number in the search box, and then select downloads and drivers again and select the newest PS driver and install that. I am pretty sure a new fresh PS driver will resolve your problem.
I am including the setup procedure below, I assume this it the process you followed.
Try a new driver. If that doesn't resolve it, possibly the machine firmware itself will need to be updated to the newest version.
The template is set up to provide centered text in the available tab printing area at each position.
At each printing position click to highlight all the text visible on the sheet. Type in the wording you desire and proceed to the next sheet.
When printing the file ignore the warning about margins.
At The Printer:
1) Load the tabs long edge feed with the smooth edge feeding into the machine. The first tab will be on top towards the front of the printer.
2) Set the paper type to [Pre-cut tabs (106-176gsm).
3) Set the number in sequence using the [up/down] arrows for the number of tabs in the set.
4) Set the paper size to [9x11].
5) Select [Confirm].
At The Workstation:
1) Select [File], [Print] and select your printer from the [Printer Name] drop down.
2) Select the [Pages] radio button and set the page range to 2-6.
3) Select the [Paper/Output] tab.
4) Select the [Select Paper] button.
5) Select [Pre-cut tabs] from the [Type] drop down.
6) Set the number in sequence using the [up/down] arrows for the number of tabs in the set.
7) Select the [Layout/Watermark] tab.
8) Select [Fit to New Paper size] and select [9x11] from the drop down.
9) Select [Rotated Landscape] from the [Image orientation] drop down.
10) Select [Ok] twice to print the job.
Jan 14, 2010 | Xerox Office Equipment & Supplies
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 05, 2008 | Computers & Internet
Mac OS 10.5 Leopard
As per someone elses post here:
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
HP DesignJet 3800cp InkJet Printer Logo
124 people viewed this question
Clive
Clive
Thomas F. Schneider
