Question about Lexmark E460dn Laser Printer
Hot to solve the problem 931.01 service printhead Error?
3 Suggested Answers
  • 6 Answers
SOURCE: 934 service Printhead error
head may be damaged, try reinstalling software first before you try to send the head repaired locally. may have to buy a new head if its dot matrix.
Posted on Aug 05, 2009
brett207
  • 231 Answers
SOURCE: how can i solve this problem? 935.10 service
This is a service error, which will need a technician to diagnose and repair.
Probably a faulty laser scanner assembly.
Posted on Dec 07, 2009
Hello, I get error code 10037 on my epson 9800 machine. It is 00010037 Print Head thermistor error. I would appreciate if you can tell me what is the reason of the problem and how can I solve it? T
Yes, the error code indicates it is a thermistor problem and it means the problem is with the printhead of the printer, the solution for this problem is replacing the printhead, but before that, you can try to remove the printhead from the printer and then clean the contacts with a cotton swab and distilled water, after that dry them up and reseat the printhead very carefully.
You can take help from the service manual, which you can download from the link below.
http://www.americaninkjetsystems.com/epson_mimaki_roland_printer_rep/9800svc_manual.pdf
Feb 24, 2015 | Epson Stylus Pro 9800 InkJet Printer
Why display error printer head too hot
According to the user manual, when this error occurs, The printer stops; the ERROR light flashes.
Caution •
The printhead may be hot enough to cause severe
burns. Allow the printhead to cool.
The printhead is over temperature. Allow the printer to cool. Printing
automatically resumes when the
printhead elements cool to an
acceptable operating temperature.
Jul 03, 2014 | Zebra 110Xi4 RFID Label Printer Transfer...
Cannon pixma mg5220 printer, b200 error msg. how do you remove the printhead ?
Error B200: A service error has occurred.
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, the device needs to be send to service for repair.
It can be that only the print head has malfunctions, but mostly it is another defect in the printer which causes also a defective print head. Changing the print head can solve the issue for a couple of weeks, but then the error will occur again.
May 06, 2014 | Canon PIXMA MG5220 Wireless Photo...
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Service Error 5200 comes up on printer status. What is the procedure for solving this error?
5200 is a temperature error of the printhead. The only repair is a new printhead, you will find the part number on the side of the printhead, it starts with
QY6-
Jan 31, 2010 | Canon i9900 InkJet Photo Printer
How can i solve this problem? 935.10 service printhead error lexmark E460dn
Dec 07, 2009 | Lexmark E460DW Mono Laser - 38ppm, 466MHz...
When I try to print on my Pixma 780 I get a message
5200 is saying the printhead got too hot, could be a shorted element, but you need a new printhead, QY6-0049-000 around $40.00
Jul 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Service Printhead Error
this problem come whene printer fuser chamber have faulty ,
fist of all do service of fuser and check
after than change pressure roler and teflone slive if problem not solve
Apr 22, 2009 | Lexmark E450dn Laser Printer
IDS failure, call HP message comes up
Hope this helps you. This error is caused by either a correct or incorrect detection of air in the manifold. The steps below will clear the error condition, which should solve the problem if it is caused by an incorrect detection of air. If there really is air in the manifold, however, this procedure will not solve the problem and the printer will have to be serviced. Step 1 - Remove all printheads CAUTION: Do not touch the printhead tower. Do not remove the printhead handle. Keep printheads out of the reach of children. Figure 1: HP 14 printhead c00042423.jpg 1 - Handle 2 - Tower
  1. Make sure the unit is plugged in and the power is turned on.
  2. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  3. Wait two or three seconds, then unplug the power cord.
  4. Open the printhead latch. See the illustration below. Figure 2: Open the printhead latch c00042424.jpg
  5. Remove each problem printhead by lifting the printhead handle and pulling up. See the illustration below. Figure 3: Remove the printhead c00042425.jpg
Step 2 - Reset the internal error state NOTE: This step must be performed before the printheads are re-installed.
  1. Close the printhead chute.
  2. Close the access door.
  3. Plug the power cord back in.
  4. Turn on the power. The front panel should read No Printhead. Will damage Product. Insert [color name] [icon] printhead now . NOTE: The carriage may make a grinding noise when you turn the power on. This noise is normal.
  5. Open the print carriage access door by lifting the handle until the door locks in place. The print carriage moves to the center.
  6. Wait two or three seconds, then unplug the power cord.
  7. Open the printhead latch.
Before re-inserting the printheads, make sure all the electrical contacts have had at least five minutes to dry. Step 3 - Insert the printheads
  1. Place each printhead in its slot in the printhead carriage. The colored shape on the top of the printhead should match the colored shape on the proper slot on the printhead carriage.
  2. Press down firmly and evenly on both the front and back of the printhead, as shown in the illustration below. Proper seating is essential to making good electrical contact.
Figure 4: Seat the printhead c00042431.jpg Step 4 - Close and check the printer
  1. Close the printhead carriage latch and make sure the loops catch the hooks. See the illustration below. Figure 5: Loops catch hooks c00042432.jpg
  2. Snap the latch into place.
  3. Plug in the power cord.
  4. Close the print carriage access door.
  5. Turn on the power.
  6. If the error clears, a message to align the printheads may appear on the HP Officejet D and HP Officejet 7100. Press Enter to align. If the error persists contact HP. Printhead replacement will not resolve this problem - the printer will have to be serviced.
Jan 08, 2009 | HP OfficeJet D135 All-In-One InkJet...
Lexmark E460dn Laser Printer Logo
411 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
