Question about Dynex "- 32"" Class - LCD - 720p - 60Hz - HDTV DX-32L221A12"
DX-32L221A12 no audio from pc via hdmi
Great picture but no audio to TV from pc. using win7 home premium and in devices only see generic driver.
4 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: Dynex DX-LCD37 Audio with HDMI
Try connecting directly instaed of through the switch box.
Posted on Jun 06, 2008
  • 5163 Answers
SOURCE: How do I print a manual for a Dynex DX-32L221A12
Dynex has the documentation for the DX-32L221A12 on the product site: http://www.dynexproducts.com/products/televisions/DX-32L221A12.html?supportTab=open . The direct link to the User Manual in English is http://www.dynexproducts.com/cms/documents/Manuals/DX-32L221A12-DX-40L260A12_11-0101_WEB_ENG_V1_Final%20lr.pdf . Since this is a PDF you will need Adobe Reader to access the file. Once in Adobe Reader you can print the document to any printer connected to your computer. If you can't print the document, you can put the file on external media (flash drive or optical media) and have it printed at your local print shop.
I hope this helps.
Posted on Nov 25, 2011
joeguest2
  • 2080 Answers
SOURCE: My Dynex DX-L26-10A display is not working. The audio is completely functional, but no matter what input I am on whether it be TV or HDMI, all I get is an illuminated but black screen. Ideas?
Most often, this symptom is a result of a failing LCD CONTROLLR (TCON) BOARD but a faulty MAIN BOARD can certainly cause very similar symptoms. Unfortunately, without a donor TV to swap parts with or a dedicated test rig, it can be very difficult to differentiate between these problems.
One quick way to test this is to remove the rear access panel on the TV and then replace the TCON board with a new one, since this is the most often the source of the trouble.
You can usually find replacement supply circuit boards online by searching for your TV's model number.
Here is a link to a replacement TCON BOARD for your TV currently available at SHOPJIMMY for about $63 US plus shipping:
http://www.shopjimmy.com/dynex-569kt04260-t-con-board.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed if necessary, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your circuit boards and confirm that they exactly match the ones provided in the online listings. Also make sure that any part you order is labelled "TESTED WORKING" in the condition description. Any part with a condition description of "AS IS" is probably faulty itself as well.
The TCON BOARD will likely be hidden under its own RF shield cover plate. Just remove the screws / tape securing this protective metal cover as well. Then unclip and remove the various electrical wire connectors leading to the TCON BOARD. Then remove the screws securing the circuit board to the frame and then remove the circuit board itself. Be sure to avoid touching any large capacitors on the power supply circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
Here is a link to another Expert's solution to a similar problem which includes links to his excellent and informative set of LCD TV / MONITOR TROUBLESHOOTING GUIDES:
http://www.fixya.com/support/t10008425-when_turn_tv_picture_flicks_off
These guides will give you some idea of the various problems with LCD TVs and monitors and the associated repair procedures.
If you choose to rate BUDMRTN's troubleshooting tips by clicking on the YES THIS WAS HELPFUL icon on his solution page at the above link, then I thank you very much for your time and consideration.
I hope that was helpful to you, good luck.
Joe.
Posted on Jan 09, 2012
Not getting all my pictures on facebook. some are blank with a little broken box on them
DYNEX DX RC02A 12 LCD TV Remote DX 32E250A12 DX 32L221A12 DX 40L260A12 DVD...
YOU WILL need the transmitter which can be ordered using the listed web site.you can then google your model# to down the the owners manual for specific instructions on your TV
Jun 22, 2015 | Facebook Apps
HP Pavilion dv6119us need drivers for win7
http://www.laptop-software.com/hp-driver/hp-pavilion-dv6119us-windows-7-drivers/
Feb 24, 2015 | HP Computers & Internet
Asus k52f laptop hdmi port no sound
Step 1:
Plug your TV into the HDMI port.
Step 2:
Right click on the audio icon on the task bar, and the click "Playback devices".
Step 3:
Choose your TV and click "Set default"
Feb 21, 2013 | ASUS K52F-BBR9 Notebook
I wanna connect my laptop(lenovo G450) to samsung series 4 lcd through hdmi cable
A HDMI cable can output both audio and video, whilst some computer with Windows XP cannot automatically switch to HD Audio output as Windows 7 can. Thus manual setup can solve the problem.
After connecting the HDMI cable, Go to "Start" > "Control Panel" > "Sounds and Audio Devices", double-click "Sounds and Audio Devices. Select "Audio" tab on "Sounds and Audio Devices Properties" window.
On "Sound playback", change "Default device" from "Conexant HD Audio output" to "NVDIA High Definition Audio".
Your television should have several HDMI ports, select the appropriate HDMI port number and check if TV is not muted.
Hope this helps.
Jul 13, 2012 | Lenovo Computers & Internet
I hope this helps.
Nov 24, 2011 | Dynex DX-LCD32-09 LCD TV
I have an hp deskjet 3920, i have not secceeded in downloading the driver from the internet. I am using a windows 7 home premium edition operating system(64bit)
Please go to this website and select your Operating System if it's Win7 Home Premium, Win7 Professional, etc.. http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=445469&lang=en&cc=us&prodTypeId=18972&prodSeriesId=445452&taskId=135
Thank you for choosing FixYa! a 4 thumbs up will be greatly appreciated for answering your inquiry for FREE.
Jun 20, 2011 | Computers & Internet
Instaling windows 7 in vaio laptop have vista orginal windows how solving the problem in instaling windows 7?
if your system came with vista originally the issue would be is you would need to know what version of vista you have on your system, the version makes the difference if you have vista home premium then your windows 7 should be a win7 Home premium as well, because if you are upgrading vista using your win7 disc and your windows version are different for example you have vista Home premium and your win7 is win7 ultimate and you do an upgrade the problem will be your product key,
but if you have a retail version of win7 and you are installing it on your laptop Vaio insert the disc in the DVD-drive win7 needs a DVD reader to be able to install win7 if you have a cd-rom it wont work, then turn the laptop off power it back up keep on tapping f12 it should bring you a boot menu, select ODD or which ever is your dvd drive then press enter then enter again if it says on the screen press any key to boot to CD, this should begin win7 installation on the screen saying windows is loading files the so on ans so fort ^_^ this will over write everything in vista but in win7 it will still create a windows.old folder from vista only from the my documents folder my picture and my music and my video and desktop Items but remember application icons will not work on win7 you may need to reinstall the program again for it to work on win7 and yeah make sure that you choose custom/advance in the selection screen do no select upgrade unless you vista and win7 are the same version eg. Vista Home premium / Win7 Home premium ^_^
Jun 03, 2010 | Sony VAIO VGN-FW390JFB Notebook
Dynex "- 32"" Class - LCD - 720p - 60Hz - HDTV DX-32L221A12" Logo
Top Dynex Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Dynex Audio Player and Recorder Expert? Answer questions, earn points and help others
