Question about Microsoft Windows XP Professional for PC
Microsoft Feeds Synchronization has encountered a problem
  • 86 Answers
SOURCE: Why am I getting error message for Microsoft Feeds
This is a problem with Microsoft's RSS Feed Reader. As most people use a different Reader (or don't use RSS at all) this can be disabled. Please follow the instructions below to disable it.
Open Internet Explorer.
Click Tools>>then Internet Options.
Click on the Content tab.
At the bottom, under the Feeds section, click Settings.
Uncheck all boxes and click OK.
Click OK to close the window.
Close Internet Explorer and reopen.
Posted on Nov 21, 2009
rajeshpait
  • 542 Answers
SOURCE: Microsoft Feeds Synchronization has encountered a
This is due to lost network connectivity or slow internet connection.
Posted on Dec 15, 2009
erone47
  • 458 Answers
SOURCE: Why Microsoft Feeds Synchronization continuous
You must have had a problem during Windows Updates.
Solve the problem by installing Service pack 3.
If you already have service pack 3 then reinstall it.
Download service pack 3 from the link below.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en
Posted on Jan 02, 2010
  • 3 Answers
SOURCE: AppName: msfeedssync.exe, AppVer: 8.0.6001.18702, ModName: user32
Antivirus and firewall prevent msfeedssync to connect.
You can use next 3 solutions (hope this help you):
NOTE: Before using ones of the next 3 solutions. You can test disabling your Anti-virus and check if the error occurs, if yes, then disable you firewall. But only for testing, AFTER test enable both AV and FW and select the solution from above that suits you better.
1. Disable the app:
Run CMD
and type: msfeedssync disable
2. Disable automatic update in IE
Internet Options - Content - Content Advisor -
"Sources” “Configuration” and disable “Search..."
3. Configure your Anti-virus and Firewall.
It depend of your software used, for the firewall you need to allow connections for msfeedssync.exe located in, C:\Windows\System32
Regards
Posted on Mar 04, 2010
  • 729 Answers
SOURCE: How do you get rid of a microsoft feeds
Hi there and welcome here.
feeds synchronization error comes IF :
1. the web pages you request feeds from are corrupt (RSS FEEDS)
2. The Internet Explorer are not function well
For 1: try to remove the RSS Feeds that are error on, you find it in the favorites under RSS Feeds (in the left side of the screen :O)
For 2 : Here you can try to uninstall Internet Explorer and install it again, you do it in this way : uninstall Internet explorer in Add and Remove programs in Control Panel, reboo the computer and install Internet explorer again ;O)
Hope it helps
Let me know
Have a nice New Year
Please rate my answer
Posted on Dec 25, 2009
Microsoft Feeds Synchronization error keeps on popping up.
Sounds like your IE is corrupt, uninstall it from Add/Remove programs, this will revert to an older version, visit Windows Updates to re-install.
Mar 21, 2013 | Microsoft Windows XP Home Edition
I often get this pop-up like every 10 - 30 seconds that (the instruction at "0x7e4195c8" referenced memory at "0x00000048". the memory could not be "read), then Click on OK or...
run a system restore back to where to computer is working fine. go to start>accessories>system tools>system restore then choose a date where your computer is running just Okay. if that will not work then uninstall some programs that you no longer need or uninstall and reinstall the program that's causing the problem. you will notice this if your running a specific program.
Feb 07, 2011 | Computers & Internet
This happens because you have RSS Feeds, from Microsoft, and they are losing the connection, sometimes, this can be quite normal. If you do not want the to appear any more simply turn off your RSS feeds.
Apr 17, 2010 | Microsoft Windows XP Professional
1. Disable the app:
Run CMD
Regards
Mar 01, 2010 | Microsoft Windows XP Professional
How do you get rid of a microsoft feeds synchronization error
Windows Internet Explorer 8
  1. Start Internet Explorer.
  2. On the View menu, point to Explorer Bar, and then point to Feeds.
  3. In the navigation pane, right-click a feed, and then click Properties.
  4. In the Feed Properties dialog box, under Update schedule, click Settings.
  5. In the Feed and Web Slice Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed and Web Slice Settings dialog box.
  7. Click OK to close the Feed Properties dialog box.
Windows Internet Explorer 7
  5. In the Feed Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed Settings dialog box.
Dec 25, 2009 | Microsoft Windows XP Professional
Nov 20, 2009 | Microsoft Windows XP Professional
Why Microsoft Feeds Synchronization continuous appear in window unsolved?
Nov 13, 2009 | Microsoft Windows XP Professional
Cannot process RSS FEEDS IN OUTLOOK
Well the link u have provided is not a RSS feed link. I suppose ur searching for some micrpsft feed links. You can find the feed links here http://www.microsoft.com/rss/
Aug 18, 2009 | Microsoft Computers & Internet
Microsoft Windows XP Professional for PC Logo
736 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
