Question about Toshiba Office Equipment & Supplies
Machine is droping develper out side. print is not solid if we touch on print so we feel develper on print. plz give me any solutin if anyone have.
How can we clear the result of print. we are facing problem in Develper of Machine toshiba e-studio 232. Machine is droping Develper outside. if anyone have any solution so plz inform me. waseem_pdk210@yahoo.com. no error code is showing. just develper problem plz help me if any one have any suggestion or solution
  • Toshiba Expert
  • 414 Answers
Set developer press 0 5 simullate enter 200 and set OR clean charger
Posted on Nov 09, 2012
  • 24 Answers
SOURCE: toshiba e studio 232 screen shows
is the finisher tray atach and connector plug in? it's possible that the connector was unplugged while the machine was on and an memory error apeared! if so, unplug the copier from power source, plug in the finisher, and plug in the power corde . if it won't work you shall check also if all doors of finisher are closed and if wasn't broken one of the sensors!
Posted on Nov 03, 2008
  • 19 Answers
SOURCE: Richo Aficio 450e photocopy machine (Error Code SC360)
Replace HDD
Posted on Dec 24, 2008
  • 990 Answers
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
Posted on Jun 02, 2009
  • 653 Answers
SOURCE: Toshiba e-Studio 232 is showing error message CF60
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Posted on Jun 10, 2009
  • 19 Answers
SOURCE: Hello, I turn on my Toshiba E-Studio 166 Photocopy
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Posted on Jan 26, 2011
How can solve km 8030 paper ground clear fault??
my dear you chek develper unit and clean unit
and grid wire change
Feb 21, 2015 | Kyocera Km-8030 With Feed, Bank, Print,...
The machines gives the codecof32
my dear your develper low or toner low or clean drum unet sensor
Dec 02, 2013 | Konica Minolta Di2510 Di251 Di250 Di2010...
Print spooler error
open cmd on your computer
first type:
net stop spooler
after that type:
net start spooler
May 22, 2013 | Panasonic DP-8016P Copier
How to reset error code c21 in the Toshiba e studio 166?
how can to reset error code c21 my toshiba e-studio 166 printer
Feb 28, 2011 | Toshiba e-STUDIO166 Printer
Copier working fine. moved from one office to another. now no print. pages come out blank. what could we have done?
Check the high voltage unit.Remove and clean the transfer / separator corona unit.
Aug 12, 2009 | Xerox 5855C Copier
Noise in the Laser Jet 1022 Printer
try and check for broken gear- tooth on one of the sides of the machine
May 29, 2009 | HP LaserJet 1022 Printer
Print a part of paper
I will recommend to do a negative post copy. Then check whether solid black or not. If not solid or blur, then the developer material might be dirty or not enough where u need to replace. If only certain area, such as top or bottom part not solid or blur, it might be caused by the roll guide also where u need to replace it.
To replace developer is very simple, take out the waste toner box, unplug the connector on the developer unit, loose one screw, and u can take out the unit. On the unit, take out the 2 screws, and u can open the cover.
May 25, 2009 | Toshiba e-Studio 350 Copier
Machine won' spin
It sounds as though the main drum bearings have failed.
If you turn the drum by hand and it feels rough or you can feel it grating or rumbling, then the main bearings have gone.
Quite a major and expensive job to put right, you may find it more econonomical to purchase a new one.
Plz rate my comments.
thanks and a merry xmas.
Dec 21, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
HP 2600N- only printing solid yellow sheets
This is easy enough - ring HP and tell them to come and replace it. If the machine is less than 30 days old (i believe) you are entitled to class it as DOA and receive a new machine rather than a fix. The solid colour is indicative of a process engine/formatter fault
Sep 16, 2007 | HP Color LaserJet 2600n Printer
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
