Question about Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190
Central heater blows hot and cold air
I am having to turn the thermostat on and off in order to get heat. i have the thermostat to 70 and the heater will blow hot air and then roomtemp-air, therefore bringing down the temperature again. it's been two days and it has not heated the house.  help please
  • Anonymous Feb 14, 2009
    My heater blows cold air and actually makes the house colder. Then for no apparent reason it starts to blow hot air and warms the house up. The heater repair man said that he could not find a problem with the heater. Any one with an answer?
Flame senser
Posted on Feb 23, 2009
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ... > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ... > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ... > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - ...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
Jan 27, 2016 | 2000 Chrysler 300M
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
2003 f350 diesel no heat
thermostat is sticking open
Dec 25, 2012 | Ford F-350 Cars & Trucks
Central heating HVAC blows cold air -
is there a light or source of heat near t stat or low battery in tstat
Jan 04, 2009 | Intertherm P3RA-048K Air Conditioner
Heater blows cold air
With the car warmed up,feel the heater hoses,are they both warm/hot near the firewall in the engine compartment?If they are both warm/hot,then the heater core should have circulation through it and it may be a "blend door" issue in the heater a/c assembly.If they are not warm/hot then the heater core could be dirty and plugged up and needs to be flushed.
If the above does not help,a drain and vacuum of the cooling system and vacuum refill will remove any trapped air.
Sometimes,clamping off the top rad hose and holding the engine rpm at 2000 rpm will force trapped air out of the heater core.(Watch temp gauge when trying this)
Lastly,a NEW thermostat doesn't mean its working correctly.
May 18, 2017 | 2005 Lexus SC300
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Omega Trane Furnace Draft Inducer Blower 115 Volt Variable Speed Fasco # A190 Logo
770 people viewed this question
Top Omega Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
