When I try to load any os it takes between 2:30 hrs and 5hrs to get to a logon screen. Can any one help?
Scan your computer by using a good Antivirus software and remove all the viruses. Also cleanup your computer drives by using 'cleanmgr' command. Delete all temporary files from temporary folder. These steps might help to increase your computer speed.
Block the Startups and Services When your computer is started up, there
might be a number of programs and services running in the background.
Some of them would be update checkers, error reporters and the rest are
necessary tools like your antivirus etc. The idea is to disable running the start-ups and service that you no longer need. Defragment the Disks My computer is slow to start up if the
disks are too fragmented. Fragmentation refers to dividing a file into
several parts which cause slow down in retrieving their contents. The problem can be solved by defragmenting such fragmented disks using the Disk Defragmenter. Defragment your Registry Registry is the database in your
operating system containing significant configurations and information.
Registry fragmentation too cause my computer is slow to start up
issue. Defragmenting the registry is too
simple. You have to download a third party Registry Defragmenter
software and install it o your system. Set Up the System for Best Performance Setting Windows for maximum performance
rather than best appearance could fix the problem. Whenever my computer
is slow to start up I perform the same task. The steps are provided
below: Disinfect the System Sometimes computer is infected by a
virus and I feel that my computer is slow to start up.. Change the
existing antivirus software and download a good one. Update its virus
definitions and conduct a full scan through it. Remove all the
infected files that found.
Replace the hdd... The motor of hdd is spinning to slow. I encounter this problems so many times on my customer PC. To verify touch the hdd and it is so hot. Check the cable ribbon maybe install wrong the blue connector to motherboard the gray slave and the black to hdd. If it is installed wrong hdd works but it will go bad soonber or later and it to late hdd is already wasted.
Hi ! my pc runs on windows xp home edition.Also on mozilla firefox,it not opening when u click with the mouse it takes 10-15 min. to open and is crashes all the time.please can u help me?thanks.
My pc r very slow. i have contect internet and this time my pc r slow. so wat is solution me...... i want fast my pc.
so i m waiting u r reply. pls solution send my email id very argent.
my email id is [email protected]
Taking anything more than 1-2 minutes to load windows says either there is a processor, or the first 64KB memory bios problem or a operating system/ hard drive problem. To see if the bios is faulty look on the motherbord for the CLRCMOS CLRRTC, or JBAT terminal if its jbat1 put jumper from pins 1-2 to pins 2-3 then back again, if its others the pins need to be shorted by a jumper cap. restart pc and see if quicker, if not it may be the CPU and only fitting a new one can illiminate that. If its a windows problem, you will need to run a disk check first, click Start Run, then type chkdsk volume:/r, or for a system files check click start, run then type sfc /scannow then hit enter and follow instructions
Please would you like to be more specific. What is the size of your Hdd and the RAM? What about the processor?
sir, when we click on send received icon then mail take more time to received mail while that mail size is normal what is problem in my pc give me solution. I m sending a message which I do received Ox800ccc19 or some time )x800ccc0F
