Question about Whirlpool Washing Machines
CAM2742TQ3 WONT FILL ALL THE WAY IN RINSE CYCLE
BRAND NEW MACHINES, COIN OPERATED, DRAIN LINES ARE ABOVE UNITS,
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Bosch WFL2450 Washing Machine wont spin cycle
Hi there, this problem sounds as though the carbon brushes are needing replaced or infact just needing to be cleaned of dust or dirt. Its very common for the brushes to be covered in dust and fibres. Im not sure where the brushes will be on this model but I hope this helps you in someway.
Posted on Sep 24, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
SOURCE: Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Door locked light flashes.
After turning off at power point, then restarting unit will commence but light starts flashing again and machine stops
Posted on Jul 04, 2010
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a whirlpool washer that only fills up half way in the rinse cycle, is this normal
I have a similar machine and was wondering the same thing.... can this be set to fill up fully on the rinse???
Sep 10, 2010 | Whirlpool CAM2752RQ Coin Operated...
Washer does not drain , rinse or spin
most common reason is the water pump has failed the unit will not spin untill it detects all the water has gone some times the motor is jammed take it off and look for a small coin or something thats stopping it if not then you may need a new pump motor
Apr 20, 2010 | GE Spacemaker WSLP1100D Top Load Washer
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Machine will fill but not complete any cycle. suspect timer
If the washer will fill on all cycles except rinse, it indicates a cold water supply problem. (Cold water is what is used in the rinse cycle). This normally would be caused by a faulty solenoid on the water inlet valve. Here is a picture. The solenoid can be checked with an ohm meter or multimeter. If the solenoid reads zero ohms, it is stuck open and the inlet valve must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Kenmore HE3T Washer
Washing Machines Logo
120 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
