Question about Compaq Presario Notebook
Problem!!Need Assistants If i use my headphone..my speaker also got sound in the same time i use headphones..i dont know how to fix it..could you teach me how to fix it?HP Presario V3000..A.S.A.P
  • Michael Fisher
    Michael Fisher May 11, 2010
    Where Do You Plug The Headphones In At?
How do i fix this? When i plug my head phones in the sound goes away.
that's the way it works if you plug in the headphones the external speakers go off. if you are not getting sound to the headphones then try another pair of headphones to see if they will work.
Jun 08, 2014 | Google Nexus 7
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
The sound is only coming out of one side.
One speaker of the headphone is weak... there is no solution to fix it, you have to buy a new one... it's a really common problem ..
Feb 07, 2012 | Sennheiser Electronic MM 400 Wireless...
Dell D810 speakers do not work, but headphone jack does work
It seems as though you might have a bad plug, There is a set of tabs that tell the laptop whether to use the speakers or the headphones. This switch may of locked into the headphones position. This is probably a case of where you would need to replace or repair the headphones port. check to make sure there is nothing in the port to block it. You can also try applying some light oil on the end of a headphones jack and placing it in and out several times to break free a possible stuck part. It also may be a case that the solder mark on the board has disconnected itself from the headphones jack and needs reseating. This would be a difficult fix but not at all impossible.
Apr 26, 2010 | Dell Latitude D810 PC Notebook
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Microphone and speakers dont work, but the headphones do.
check the pin. is it the same with the head phones??
Nov 06, 2009 | HP Pavilion dv6000z Notebook
Realtek Sound device problem
i dont have a volumecontrol
Jun 02, 2009 | Computers & Internet
Sound problem
ok me too, since i install the win 7 in my sony vgn-fz15g, the sound is also coming from speaker too while headphone is connected, and earlier in vista it disable the speaker automatically, i check the sound window, in win7 speaker/headphone is given together, i can not disable one at a time, i think its a driver problem, sony customer care people told me that they have still not tested this model on windows 7 so thats why they are not releasing the driver, if any one have the link for he latest sigmatel high definition driver then let me know that, because this is the complete problem
May 27, 2009 | Sony VAIO Notebook
Because of Gigaware headphones, my speakers dont work
it sounds like the headphones shorted out the usb on your system, you might try some speakers that are not usb and see what you come up with,,,also check and make sur your sound isnt muted on the master control for the volume
Feb 26, 2009 | Audio Players & Recorders
Headphone jack is finicky
Does this help?
http://www.fixya.com/support/t882518-right_speaker_stops_working
It's probably the socket - it may be that it's coming away from the board or the switch inside that cuts the speakers when you use headphones is faulty. It may be a simple resolder or you could replace the part.
Jan 30, 2007 | Harman Kardon HK19.5 Computer Speakers
Compaq Presario Notebook Logo
50 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
