Question about Brother HL4040CN Laser Printer
Brother HL-4040 Laser Printer -- Print Unable 6A Error
Brother HL-4040 Laser Printer -- In several attempts, I have tried to follow the instruction on the printer which tells me that the printer will automatically restart in 15 minutes (red light). When it does, what comes up is "print unable 6A". It also says to turn the printer off and back on. As I said before, there has been many attempts with no success. Please help!
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Dec 05, 2012 | Brother DCP-8020 Laser Printer
I am trying to hook a Brother HL-2140 laser printer to a dell computer. I am unable to print since I've recently hook up the new computer. I hooked everything up like how it was on the old...
Re boot the computer with ,( wired or wireless printer?), the printer cable in the USB port in the laptop/desktop, the windows version you have will ID the device and try to load a driver, or Go to printer in the start menu and ADD a PRINTER the software will search for the attached printer. OR use the software that came with the printer, load into the Dell and follow the instructions.
Nov 10, 2012 | Brother HL 2140 Laser Printer
3b error code on display unable to print
Sorry, this is a serious error and it means the PC board is toast. On mine, it gets to 22 on the counter (I assume it's a RAM integrity check) and then the LCD turns red and says "Print Unable 3B". When I called Brother they told me I needed a new PC board, which by the way is very hard to get to (you have to disassemble everything, then take apart the printer piece by piece). The price for the PC board is around $100 plus labor, so you're talking easily $200 to fix this.
Thanks Brother for making a self-destructing Lemon of a printer, the Brother HL-4040. And thanks for telling me I was on my own and to fix it a local repair shop.
May 19, 2010 | Brother HL4040CN Laser Printer
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
Mar 24, 2010 | Brother HL 2140 Laser Printer
Print Unable 20
Bad news. The laser diode responsible for printing black has up and died. You need a new Laser Unit, part number LR1461001. Brother has released a "Service Update" about this one; the instructions for replacing the laser unit run to nine pages. If you're within the 1-year warranty, it won't cost you, but it won't be printing with it today.
Jun 11, 2009 | Brother HL-4040CN Laser Printer
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
May 28, 2009 | Brother HL-2040 Laser Printer
Message E52 Service call what does that mean? (Brother HL 7050)
Probably a fatal error. Bad Laser Unit. Try unplugging the power cord for 10 seconds.
Jan 06, 2009 | Brother HL 7050 Laser Printer
Brother HL4040CN Laser Printer Logo
1,616 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
