Manually turn on base heater, thermostat broken
How can I manually turn on my heat while the thermostat is broken? I have a honeywell F8-9446 base heater in my apartment.
  • 659 Answers
You can jump your w terminal over to the r terminal for manual but remember that the unit will not cut off on it's own.
Posted on Jan 05, 2009
What do you do when the face of the thermostat is broken off and I cannot see what any of the settings are? It's a Honeywell programmable thermostat.
most likely you will have to replace thermostat...if you go to honeywell.com they may still have the thermostat but it is possible the stat has become obssolete and will require a totally different one... for the time being if you need heat you can manually jump it but it will not shut off until you take the jumper wire back off... jump out the "r" terminal and the "w" terminal and should bring on the heater until you can get it replaced... if you have any problems with installation repost with brand and heat pump or straight cool one of us will help you out....good luck to you..
Jan 11, 2011 | Honeywell Programmable Thermostat Heater
I have a Honeywell CT500A thermostat. I set it at 68 degrees. the room temperature is 62 degrees. The unit cycles on and the "flame" icon shows on the screen, but then the unit goes off ( the...
Here is a simple way to tell. Remove your thermostat from it's mounting plate, locate the wiring, the red and white are low voltage control wires. Disconnect them from the base and join the two together if the furnace runs you need a thermostat if not it is in the controls to the furnace.
Dec 27, 2010 | Honeywell CT500 Digital Heat / Cool Manual...
Installed a Honeywell Thermostat - Heat will only come on when you manually turn up the thermostat - it is not coming on by itself. We have put on a new regulator on furnace, a new box for the Thermostat...
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 09, 2010 | Honeywell (CT62B1015) Baseboard Heater
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
571 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
