Question about Maytag MSD2656G Side by Side Refrigerator
Terrible smell coming from bottom of unit
Looks like there is a drip pan in front of motor - the drip pan is filled with something that looks like congealed cooking fat. How do you get the drip pan out to clean it? I've taken off the cardboard cover on the back but it doesn't appear there is any way to get the drip pan out to clean it. Help!
  • 716 Answers
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Posted on Jan 05, 2009
Model 610 - how do I locate the drip tray and how do I remove it? The power was lost after TC Marcia and products dripped in the fridge and freezer causing a terrible smell.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Plastic holds odors. The smell may not becoming from your drain pan, but more likely the liner.
What to do:
1.) Remove the shelves, ice bucket and crisper drawers and scrub them with a baking soda base cleaner.
2.) Scrub the liner walls.
3 .) There are deodorizers especially made for refrigerators; One for the fresh food section and one especially for the freezer section. You can get these for any appliance store.
4.) Ok, lets check the drain pan.
a.) Unplug your unit or turn the main breaker off.
b.) Raise the two leveling screws in the front to allow you tp pull your unit out.
c.) Having enough room to get behind your unit, unscrew the bottom cover.
d.) Observe. You either have the terrible drain pan design, where the drain pan is fixed on the top of the compressor with hi-temp adhesive. Do not attempt to remove. Over time the adhesive dries out and the drain pan falls off.
The other type of drain pan is almost just as bad. You have to unbolt the compressor and other things to access. Do not attempt this.
What field technicians do when there is a drain pan leak, is repair the leak with duct tape and a high temperature silicone adhesive. In this case if there is an odor, sprinkle 1/2 cup of baking soda around the drain pan.
Feb 26, 2015 | Refrigerators
Terrible foul ordor coming from air conditioner
Two things may be causing this. A dirty air intake filter and/or the drip pan is not draining as it should.
Remove the front air intake filter and clean it, if necessary.
While the front is Off and the filter is removed, look at the drip pan under the mechanicals. If you see water standing, the unit is not draining as it should. This can be the result of the drain hole near the rear of the drain pan being clogged and/of not enough downward tilt on the rear of the unit. The general rule of thumb is 1/4" to 1/2" of downward tilt. Finding the drain hole can be a challenge, as the clog can blend in with the drain hole. Be patient and persistent in locating it. A pipe cleaner works well to clear the hole.
If none of the above applies, look for dark stains in the drip pan. These stains could be mold. In which case, add a couple of drops of bleach to the water in the drain pan. It may smell like bleach for a while, until the water dilutes it and drains it and the mold away.
Hope this helped you and thanks for choosing FixYa.
Aug 07, 2011 | Kenmore 75121 Thru-Wall/Window Air...
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
There is a bad smell coming from the back of the fridge. The inside smells fine, the freezer does not smell either. It looks like there is some kind of tray inside the back of the fridge. Its is filled...
If you are referring to the drip pan that on the bottom of the fridge, that could be the source of your odor problem. Take the pan out and check to see what is in it. Normally there should only be just water that comes from the defrost cycle.
May 13, 2011 | Refrigerators
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator is one year old. There is a bad
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} You may have had something drip and somehow get under the fridge. I know blood dripping from meat will smell. It could have dripped down through the defrost drain tube to the pan underneath. You can access the pan from the rear by removing the cardboard cover. If the smell seems to be coming from the pan, it's difficult to remove so I would just pour some bleach in it to kill any smell and you may can wipe it out from there. The drain tube may also have the smell in it so you can pour some bleach into it from the inside of the freezer at the bottom of the rear panel. You can move the fridge to see if anything is pooled on the floor that might smell.
Jan 06, 2010 | Whirlpool Refrigerators
Stink-ola!
I would call out Maytag as it looks as if an insulator on the motor is burning out.
Or a connector is overheating
Get it checked in case you have a fire
Jul 30, 2009 | Electrolux Refrigerators
Foul odor from beneath the frige!
You have a couple possibilities. Either something spilled in the frig and ran down into the drip pan or you have a dead critter under there. The pan is not removable and cleaning it is a pain. take a good look under there from the back and the front.
Eric
Jun 24, 2009 | Refrigerators
Bad odor coming from drip pan when compressor kicks own[when dry]
I just had the same problem with my kenmore side by side. I have been noticing a nasty smell for the last couple weeks when the fan comes on. My husband just took the whole back of the refrigerator apart and put a flashlight in there. We could see the drip-pan and it was filled with stinky black mold!! It was very hard to remove, but he managed to get it out by taking the lower front (where the filter goes) apart and then he was able to slide out the drip pan and clean it out! Problem solved.....but Kenmore should really make the drip pan more accessable!
Apr 12, 2009 | Frigidaire FRS26ZSG
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Maytag MSD2656G Side by Side Refrigerator Logo
770 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
