Question about Dryers
Avion ceiling fan remote code model UC7086T wont turn on or off
Code needed
4 Suggested Answers
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
SOURCE: Hunter 52" ceiling fan model 23457-380, the remote lights up
check the hard wiring from the factory. Where the light kit attaches to the fan check the wires in the factory cubes to make sure none are coming off. I had a similar problem that kicked my **** for a few minutes but I saw a loose wire after a bit of research. My fan also clicked but never turned on. Also pull the chains on the fan/light to make sure they are on. Hope something works for you.
Posted on Aug 21, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
Where can I find a reciever for my Avion ceiling fan
Who makes this fan? I've never heard of this model.
Oct 09, 2014 | Dryers
Need code for Concord ceiling fans
You have this backwards. The code is stored in the remote. The receiver is located inside the fan housing. You can try removing batteries from the remote, pressing all buttons to eliminate the possibility of a stuck one, reinstalling batteries (or installing new ones) and testing operation. If no results, disconnect power at the ceiling fan source, not the fan itself. Pause briefly, reconnect power and test operation.
Sep 02, 2014 | Concord Fans Dryers
How to install universal remote in a 52 " hampton bay ceiling fan ,model # 24754
Universal remotes have a code search button or sequence. Turn on your appliance, activate code search, & press the power button until the appliance turns off, then press the set button.
Jun 19, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Sometimes my hampton bay ceiling fan goes on by itself . It has a remote control switch only. It is a model 08060
you probably have a neighbor with the same remote .. each fan has a set of code switches on its receiver .. what ever code is selected by the little switches on the receiver (box in the fan) also must be set into the remote control (code switches in the battery compartment of the remote) .. either you or your neighbor will have to change their code ..different codes wont interfere with each other ... if the fan came with the remote control then the switches might be available on the top of the motor housing .. remotes that have been added on require that the lamp section be removed to get access to the receiver .. some older fans dont have a code selection .. the code is stamped on the receiver .. in that case then maybe your neighbor could change his code ...
once in a while a strong or local transmitter will interfere and set the fan on .. if you are near a radio transmitter, CB or ham radio ..
May 25, 2010 | Hampton Bay 24002 Ceiling Fan
Need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
Apr 24, 2010 | Hunter Ceiling Fan Light Remote Control
I need a remote
You can buy a remote kit at most electric or home improvement stores. It will come with instructions and needs to have the receiver installed in the canopy of the fan itself. They usually have dimmers for the lights on them, so do not use CFL bulbs in the fixture. Lowes sells one made by Harbor Breeze for about $30-$40. Good luck.
Feb 27, 2010 | Hunter 23827 Classic Original White 42"...
Ceiling fan and light with remote turns on and off by itself
Both the remote and reciever in the fan base have the ability to have the codes changed. What is happening is you are getting radio interference that is causing the problem. Change the codes by either switching the switches in different positions or adding more dip clips that came with the fan. In any case change the codes in both the reciever and remote to the same code and you should no longer have a problem. Usually the place to change the code in the remote is in the battery area and are small switches (usually 5 or 6 of them) and unfortunately you will have to take the fan down to do the one there.
Oct 12, 2009 | Hunter 52" Ceiling Fan With Light And...
I bought a hampton bay ceiling fan model uc7083t but i didn't
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Need code for remote to ceiling fan
There is no set code from the factory; usually all the dip switches are in the same direction. In order to find the code, you will have to take the fan down, pull the remote out far enough to observe the dip switches, and then set them the same way on the remote.
May 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Hampton Bay 46056 fan
I have three Hampton Bay Ceiling fans with remotes for eight years. I doesn't help when a neighbor buys the same make and model. So, I had to come up with a different code for mine. I had to change the code for the remote and match it with the code in the fan. To change the code in the fan, that depends on the type of fan you have, some you would need to look on top of the fan and use a skinny stick to change the code, other's you would need to take the light fixture down to get to the controller box to change the code. I have both types, this is how know. PS. if ever, which will happen, if the fan doesn't respond to the remote then you would need to replace the controller inside the fan. Here's the warrenty no. 800.749.3267 for replacement.
Dec 24, 2007 | Hampton Bay 46056 Callaway II Ceiling Fan
Dryers Logo
1,176 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
