Question about Brother GX-6750 Typewriter
Cara pasang correction tape pada gx-6750 - Brother GX-6750 Typewriter
  • 3594 Answers
SOURCE: brother GX-6750 correctronic
Check the print wheel to see if any spokes are bent or missing, be sure that you have the proper correction tape (tack free) and that you are not in proportional space or have an international print wheel.
DickyO
Posted on Mar 20, 2008
  • 329 Answers
SOURCE: Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Posted on Jun 12, 2008
t0pc4t
  • 132 Answers
SOURCE: correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
Posted on Aug 19, 2008
rylee_smith
  • 8619 Answers
SOURCE: Brother GX-6750 wrong characters problem.
Hi!
You are right. It seems that your daisywheel needs resetting. To reset it hold down the "CODE" key, while holding press the Reset key "Q" and then release.
If the wrong characters continue printing, change to a new daisywheel.
If you are still facing the same issue or problem persists contact your Authorized Brother Service Center. You may locate your authorized Brother service center by contacting them at 1-800-284-4357 or visiting them on their website or even e-
mail Brother Customer Service on the following link--
Brother Customer Service Centre
Phone Brother Customer Service:
1-877-Brother (877-276-8437)
9:00am to 6:45pm Eastern Time
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 28, 2009
FJA Products
  • 30 Answers
SOURCE: installing correction tape on a Brother GX 6750
Hello- Here is the page that provides pictures as well as an easy 10 step procedure.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ML_100_EN_216.PDF
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Posted on Jun 10, 2009
CORRECTION RIBBON ON A GX 6750
make sure the dull side is toward the paper
Jul 11, 2014 | Brother GX-6750 Typewriter
Where can i buy correction tape for the brother gx 6750?
Correction tapes are available at any office supply store you want an IBM selectric DRY lift off.
General ribbon T355.
DickyO
Jun 09, 2011 | Brother GX-6750 Typewriter
Installing correction tape on a Brother GX 6750
Take care,
Duane ONeil
www.fjaproducts.com
800-982-9989
Jun 06, 2009 | Brother GX-6750 Typewriter
Lift off tape
Does the tape lift up far enough for correction? If so check to be sure the dull side of the tape is facing the paper. Then be sure you are using a correctable ribbon, the feed wheel should be either yellow or orange. DickyO
Jun 02, 2009 | Brother GX-6750 Typewriter
I have a gx-6750 typewrite and i lost my hand book and i trying to ajusted my margin but i don't have a margin release button, so can you help me find this button please?
i have gx-6750 typewriter and i lost my handbook and i trying to connect the correction tape into the ribbon. please can you help me to put this correction tape.
Mar 08, 2009 | Brother GX-6750 Typewriter
Brother GX-6750 correctronic
DickyO
Mar 16, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
270 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
