Question about Dell Zino HD iZHS2932NBK Desktop
I have a Dell Inspiron Zino 400 HD and for some reason it can not obtain an IP address. I have tried fixing the connection, the cable works and my network works with two other pc's. It tries to connect then sometimes it does but then will go back out once there is a reboot or powered off or it goes into sleep mode. I have had the unit in to be totally wiped clean, and everything reinstalled and it still does this. There IS an internet connection, but it can't get an ip address to get on. is the network card going or adapter card? The tech says the hardware is all good.
sandrew
  • 2961 Answers
SOURCE: Ethernet Problem
If it is telling you there is a conflict the drivers are working it is the properties of the network card that are incorrect. Click Start>Run, then type ipconfig /flushdns then press enter.(note the gap between ipconfig and the /). Go to the properties of your network card and on the TCP/IP line click properties and tick 'Obtain ip address automatically'
Posted on Mar 06, 2007
SOURCE: failure to acquire IP address
How is the DHCP setting of the modem configured?
Posted on Nov 05, 2007
dan231
  • 236 Answers
SOURCE: Have internet connection but browser won't open
try pinging google.com from the problem pc.
  1. Go to START
  2. Go to RUN
  3. Type in CMD [hit enter]
  4. IN the dos window, type : ping google.com
  5. hit enter.
If your pc can reach google, it will ping back 4 successes
I would install and run spybot from spybot.com. That is a spy-ware checker program and is free.
Post back with results.
Posted on Dec 17, 2008
  • 24 Answers
SOURCE: Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Posted on Jan 03, 2009
  • 7 Answers
SOURCE: Dell Dimension 2350 wireless connection works / wired doesn't
have you tried replacing the network cable,also try a different port on the router
Posted on Mar 26, 2009
How do I fix blue screen in dell zino 400 desktop?
What was the last thing you installed on it? Go to safe mode and remove that instillation. Also I would suggest downloading three service programs and run them in safe mode as well
Superantispyware (free edition)
Malawarebytes (free edition
Advanced System care (free edition)
If you still get the issue then back up your data and then do a system restore.
May 07, 2014 | Dell New Inspiron 400 Zino HD Black...
Inspiron zino HD won't boot up it just stays at the dell screen
Try booting into safe mode restart comp and its 1 of the f buttons f5 or something ea model number is different when in safe mode make sure you go to safe with networking and download new drivers of that doesn't work let me know ill walk u thru how to Chang the way you boot up your pc
Apr 03, 2013 | Computers & Internet
'no signal' inspiron zino 410 hd
Check and reseat ALL cables, swap cables, perhaps the Graphics is bad? Have you tried to boot to safe mode, any change?
Mar 23, 2013 | Dell Inspiron 410 Zino Desktop HD AMD...
Dell zino 400 user manual wanted
Try this site:
http://search.dell.com/results.aspx?c=us&l=en&s=gen&cat=sup&k=inspiron+zino&rpp=12&p=1&subcat=ddc&rf=any&nk=f&ira=False&~srd=False&ipsys=False&advsrch=False
or:
http://www.aeato.com/users-manual/dell-inspiron-zino-hd-manual-dell-inspiron-400-manual.html/
Jan 20, 2013 | Computers & Internet
I have a Dell Inspiron Zino 400 HD and for some reason it can not obtain an IP address. I have tried fixing the connection, the cable works and my network works with two other pc's. It tries to...
You don't say what operating system you are using? If you are using Windows you may need to have " .Net framework v 2" and up installed. I have seen this problem on numerous occasions. You can download the first framework file on a different pc and install from a Memory stick. The file you need is called "Dotnetfx" (I think) or something close.
Nov 08, 2012 | Dell New Inspiron 400 Zino HD Black...
Inspiron zino hd Dell Ethernet port not working
Go into Bios And re enable it sometimes computers just act crazy
Sep 07, 2012 | Dell Inspiron Zino HD Desktop Computer...
Dell inspiron 400 W7 dont wake up, monitor and startbutton(yellow) says its sleeping..how can i wake up?
You need to call the service centre. I've had this happen to my computer and this is not a DIY project that can do any good. If shutting off the power and then switching it on again after a while isn't working, then there's something seriously wrong inside.
Jul 13, 2011 | Dell Inspiron Zino HD Desktop Computer...
My dell zino has an amber power light. what can be the possible issue?
This is a hardware problem. Try disconnecting all cables behind the tower then press and hold the power button for 10 seconds. After that try connecting just the power cable and turn on the pc. If there is no change (power light is still orange), it could be numerous things. like your power supply , memory, motherboard or processor. If it works then one of your external devices is causing this problem. If you can open your tower (just incase power light is still orange) try removing the memory and cleaning the contacts using a pencil eraser. Rub it to the gold contacts to clean it (please refer to the manual to do it).
Apr 22, 2011 | Dell Inspiron Zino HD Desktop Computer...
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Dell Zino HD iZHS2932NBK Desktop Logo
47 people viewed this question
Alun Cox
