Hitachi washing machine SFP80CJ has error code E4
  • KO SAI Dec 17, 2017
    model NW-SK61 (CP)
    error coad E4
    what this is?
    Dedicated:
    Visited the website for 20 consecutive days.
  • 344 Answers
Get the User Manual here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjI0ebOo5DYAhVJ0oMKHUjCDH0QFggvMAE&url=http%3A%2F%2Fwww.hitachi.com.au%2Fdocuments%2Fproduct%2FSFP80CJ_manual.pdf&usg=AOvVaw3jsu2BCrK_z4vW8APx3Zws
See page 48 titled Alarm Mode Indicators.
Also, get Hitachi support here:
https://www.hitachiconsumer.com/home/others/support
Good luck.
Posted on Dec 17, 2017
jyackle5
  • 8197 Answers
SOURCE: the washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Posted on Dec 19, 2008
SOURCE: i have a stirling washing machine xqb90-701clps
my machines not washing properly i think.. The wash is complete but theres still powder on the clothes.. What do i do to solve it?????
Posted on Sep 06, 2010
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Posted on Dec 19, 2010
  • 170 Answers
SOURCE: The washing machine wont stop
If that is a whirlpool as you do not have a brand or mod # that would most likely be a flow sensor. It is located under the top cover. remove screws top rear remove cover on top of machine. you will see that device in the tubing located just after the water inlet valve it will be white round device and most likely will have to small blue wires going to it.That is a somewhat pricey little part like 100.00 last time I got one but with whirlpool who knows could be more or less now. On that note might be cheaper to have the unit looked at by a pro. If you remove the lower kick panal you should find the tech sheet that will tell you what the code means but I'am sure it is overflow .. If you need more help please ask....Thanks for voting good luck
Posted on Mar 16, 2011
SOURCE: Hitachi SF-P95FJ WASHING MACHINE ERROR
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Posted on May 17, 2011
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
Samsung trouble shooting
The E4 is an error code. What the washing machine "is trying to communicate" to you is that it has detected a load imbalance at the clothes being washed; thus it won't be able to spin at full speed. Maybe it stops waiting for you to distribute the clothes more evenly. See more about error codes at http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html.
Aug 28, 2014 | Washing Machines
Hi all, can you help me to solve this E4 problem for my washing machine HITACHI MODEL SF-T1120X
E4 is an unbalanced error- the load in the drum is unbalanced. Try switch off the power and re arrange or remove some of the items to be washed.
Jan 03, 2013 | Washing Machines
Got a logik washing machine error code e4. what the problem thanks
My washing machine in a logik and is displaying a E4 error code any now what's wrong wiv it
Jan 13, 2012 | Washing Machines
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
Oct 29, 2010 | Washing Machines
The washeer machine give a error code E4
Dec 19, 2008 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Washing Machines Experts
