Question about Toshiba Satellite A105 Notebook
When booting up, when windows is finished I cannot work mouse
I have Toshiba A75-S2112. When I turn my computer on it will ask me to login. At this point my mouse or touchpad works. After I login my password and windows boots up I cannot work my mouse or touchpad. Also when it finishes booting It has restore desktop but I cant push the button to make it restore the desktop. PLEASE HELP. Thank you, Michael Valentine.
  • drill1503 Jan 05, 2009
    When I was trying to log on to windows the computer had a small light on just below the F numbers. I would not let me use the numbers from 7 -9. I went into setup and installed password for supervisor. It still would not let me logon. I shut the computer down and when I turned it back on it let me put my password but now I cant use the mouse or touchpad.
  • Alcatrazx
    Alcatrazx May 11, 2010
    What was the last thing you did with the laptop? It is very important to tell us
    Scholar:
  • 65 Answers
Dear sir
As it happens I still need some clarification what you were doing just before this incident happened but i will provide you a solution which might help you
ASSUMPTIONS MADE:
I am assuming that the operating system is XP/VISTA and that you might have installed a new device or new software on the system (mind you this could also mean that you were browsing a site and you got an ActiveX control installed which might be causing the issue!)
SOLUTION 1 (OFFENDING SOFTWARE OR DEVICE DRIVER):
1. Boot the computer
2. Just after the TOSHIBA logo comes up Press F8 and keep holding it until you get into a menu which lets you choose to boot up the operating system in SAFE MODE
3. Go in the Add / Remove programs and uninstall the offending program or hardware device which might have caused the issue.
SOLUTION 2: (Active X control or some other Malware which might have installed unknowingly)
1. Still in safe mode Use adaware or some other spyware removal tool which you might have installed (if in XP). Vista makes good use of Windows Defender. Whichever the case if you have windows vista ... go in control panel find windows defender and make a full system scan for potentially malicious software and remove what might be causing the issue. After spyware removal.
2. Go to your virus killer and perform a full system scan for any viruses and do the same. If you don't have these installed ... get hold of another computer with internet connection.
3. IF YOU DONT HAVE Antivirus and antispyware: Get hold of AVG Free edition and LAVASOFT ADAWARE PERSONAL EDITION. BOTH are free and very good. install them and repeat the above 2 steps.
SOLUTION 3: Still cannot solve the problem?
1. Go to the other computer get hold of tuneup utilities
2. Reboot in safe mode as explained above
3. install tuenup utilities (trial will still work fine)
4. Go to >> Registry Cleaner >> Clean all and let it do the rest just follow the onscreen instructions and it should give a good clean to the system.
5 Reboot and Try to see if the system works.
Solution 4: If STILL YOU CANNOT See any Improvements
1. Go again in safe mode as explained above and go to tuneup utilities again.
2. Choose Startup programs and UNTICK ALL the starting programs which you have on the system as it is clear that there must be something which is not allowing the system to start up properly.
3. Now ONCE you get the system BOOTING NOT in SAFE MODE go again in tuneup utilities and start adding the startup programs one by one until you spot the offending program! TADA. Now you know what you have to do in this case. Go to step 1 of this solution and choose and untick ONLY THAT PROGRAM which is causing the issue. Then uninstall it in normal mode.
Solution 5: The SAD one
1. Go to safe mode as explained above. Backup all your data which you might need to keep
2. Get some technician and reformat the system. Install the necassary drivers. Office / Outlook / antivirus / antispyware or in the case you got quick recovery REFER to your MANUAL and perform full system recovery. This is typically by pressing ALT+F10. BUT BEWARE THIS will MAKE you LOSE ALL YOUR DATA SO BACKUP FIRST the documents as explained in thsi solution. REFER to MANUAL of LAPTOP to see if you have this system recovery feature. If laptop is quite new (2 years or so) you should have it.
I hope that this FIXYA was of help as i did not have enough details.
CHEERS
Posted on Jan 07, 2009
A75-s2112 unable to connect after hibernation
Yes! disable hybernation, this causes all kinds of problems from window file corruption to complete shutdown of your system, "worst idea that microsoft came up with" once you do that the system will start to run better, and when not in use shut yor windows down.
Apr 22, 2012 | Toshiba Satellite A75-S2112 Notebook
I have a Toshiba A75-S2112 laptop. I hit the debug button when it was booting up and now it will not boot-up to anything. It just sits there with a black screen and the fan turned off. I am trying to...
The computer starts but, when you press a key, nothing happens.
You are probably in Standby mode and have a software or
resource conflict. When this happens, turning the power on
returns you to the problem instead of restarting the system.
To clear the condition, press Ctrl, Alt, and Del simultaneously
then select Shutdown, then Restart to restart the computer.
Mar 24, 2011 | Toshiba Satellite A75-S2112 Notebook
Need to install DVD rom driver for toshiba A75-S2112, where can I get the driver download?
You probably won't need one, most are OEM and will work with a drive supplied by windows.
Should you wish to try and find one, its best to go the the DVD manaufacturers website follow links to support and/or downloads to see if there's a driver for your model.
May 01, 2010 | Toshiba Satellite A75-S2112 Notebook
Toshiba Satellite bypasses bios and boots straight into windows please help. Pressing F2 or trying to boot into safemode does not help.
sometimes thewindow of time you have to hit the f2 key is very short. if you can't open the bios by tapping on the f2 button before it says "starting windows", try removing one the the memory sticks and restart with just one installed . The computer should see the change and prompt you into the bios.
Regards
Apr 02, 2010 | Toshiba Satellite A75-S2112 Notebook
I have a Toshiba Satellite A75-S2112. It is
there is a panel underneath with a small phillips head screw holding it. take battery out first, then flip computer over. Take out screw(place in zip loc bag for later)..ground your hands on metal somewhere, and then release the memory cards, by holding extreme outside edges. make sure NOT to touch gold fingers. Make certain you have compatible memory before you do this.
Nov 29, 2009 | Toshiba Satellite A75-S2112 Notebook
My Toshiba laptop is 4.5 years old, it shuts off after 10 minutes, why?
first try to format the c drive and reinstall the OS if its not working .........
its may be the problem with the smps of the laptop ................
Oct 07, 2009 | Toshiba Satellite A75-S2112: A75-S2112...
Mouse or touchpad not working
add an external mouse/keyboard to fix the onboard fault.
check the device manager for any yellow exclamation marks. as there may be a faulty or corrupt. keyboard/mouse touchpad driver.
other option, is to add remove touchpad drivers, and re-install.
finally, you could check if the settings are correct in the bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 05, 2009 | Toshiba Satellite A105 Notebook
A brobblem with my chrger
Here is the replacement Toshiba Satellite A75-S209 A75-S2112 AC Power ..
Part number: PA3290U-2ACA, or PA3290E-2ACA
Dec 20, 2008 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A105 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
