Question about Sharp EL-1750PIII Calculator
Load Paper on SHARP EL-1750PIII
Help! I can not figure out how to load the roll of paper. WE have 3 machine and no paper in any of them.
  • 3 more comments
  • cas9141 Jan 05, 2009
    I cut the paper on an angle and loaded in the back of the machine while pressing the + button.
  • Anonymous Mar 09, 2009
    can't load paper
  • sgbrown967 Mar 17, 2009
    I have no manual and have no idea how to load the paper. Help!
  • Anonymous Mar 26, 2009
    I can t figure it out either....
  • Anonymous Apr 12, 2009
    loading paper
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sharp Master
  • 102,366 Answers
Follow the illustrated instructions on the first page of the manual at http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1750PIII.pdf
Posted on Jun 09, 2013
  • 168 Answers
SOURCE: where do i put the paper into to replace a new roll
There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
Posted on Feb 04, 2008
  • 168 Answers
SOURCE: Load new reel of paper
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. > (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Posted on Feb 10, 2008
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
SOURCE: I'm trying to load paper into a Sharp el-1701c that I inherited.
My wife solved it by finding a thin little slot on the back of it where you put the paper in. Worked
beautifully. Thanks any way.
Posted on Dec 20, 2008
  • 207 Answers
SOURCE: I need to change the time on my Sharp EL-1750PIII calculator
You can access the .pdf manual for your particular calculator here:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Page 1 for how to set date/time:
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Posted on Apr 27, 2009
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Loading paper
    Follow the illustrated instructions on the first page of this manual.
    Jul 18, 2008 | Sharp EL-1197PIII Calculator
    Sharp EL-1750PIII Calculator Logo
    2,484 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
