Question about Whirlpool GFG461LVS Stainless Steel Gas Range
GFG461LVS oven won't light
The broiler and burners work fine, but my oven won't light. I can hear the igniter clicking, but then nothing happens.
Agent Don
  • 310 Answers
SOURCE: Gas oven won't light
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=358497
Gas oven won't light (by 2 users)
Posted by MBeird on Jan 18, 2008
Can hear the clicking of the auto starter when starting the oven, but it stops after 5 seconds and then the oven simply fills with gas. Broiler still works fine as do the stove top burners. Any thoughts?
Good question? You may have a plugged up burner and or the pipes or jets may not be adjusted correctly and it could be your igniter on the gas range because it is not igniting the spark to create the flame. You may want to have it check out with an authorized service repair tech to make sure it is safe and will function well. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Posted on May 05, 2008
SOURCE: whirlpool gas range
You may have a bad spark/ignition module, it is located under the main top (on most models) and tells the burners too spark
Posted on Jul 25, 2008
aborcass
  • 2651 Answers
SOURCE: WHIRLPOOL SUPER CAPACITY 465 SF385PEGZ3 NO OVEN/BROILER
sounds like an issue with the spark module, altough that module tends to be really relliable.i would try removing pawer to te unit. checking the outlet for proper grounding,and replugging unit see if that works for you
Posted on Oct 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
  • 160 Answers
SOURCE: oven won't
if you can hear gas when turned on then its likely to be a faulty/dirty burner. No gas flow then its the thermostat or dependant on model a faulty gas relay/valve
Posted on Dec 22, 2009
Whirlpool gfg461lvs broiler won't light
Hello. How old is the range? The broiler ignitor might be worn out. The part number you might need is 8054129. The ignitor for the bake is 9758079. I hope this helps you.
Sep 12, 2015 | Whirlpool GFG461LVS Stainless Steel Gas...
Whirlpool WFG361LVS2 oven. Broiler and burners ignite but oven will not. I can hear gas and the igniter sparks but will never light the oven.
get someone to hold a long gas match near the main burner when you try the oven . If it lights then I would suspect the igniter. even tho you can hear it snapping .
Jan 10, 2015 | Whirlpool Kitchen Ranges
Viking VGSC3676BSS oven wont light
Check the igniter and the burner near it - you may just need to clean it. If you try, you can probably even get to some point where you can observe whether the igniter is sparking in the gas path or not.
You may also be out of gas, the burners just running on the last dregs of gas in the pipes.
Aug 12, 2014 | Viking VGSC3676BSS
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven won't heat up when baking (Maytag MGR5775QDS)
Check the Manual/Auto Clock setting to be on Manual not auto . The Oven is waiting for the Right Time to start up .
Jun 13, 2012 | Maytag MGR5775QDS Dual Fuel (Electric and...
On my whirlpool gas range only 1 burner out of 5 will ignite. oven light works, oven ignites. only 3 months old and worked fine until now.
Most often when cleaning, soapis left behind and obstructs the flow of ignition gas normally directed at the exact point of the spark. Check this area and use a small wire brush to clean these area of the burners that do nto work. Let us know if this helps. Eric Campion
May 19, 2012 | Whirlpool GFG461LVS Stainless Steel Gas...
The burners will not light. I hear a clicking noise but no sparks. oven and broiler works fine
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Jan 16, 2011 | Microwave Ovens
Go Ahead. Use Us.
Jan 18, 2008 | Whirlpool SF367 Gas Kitchen Range
Whirlpool GFG461LVS Stainless Steel Gas Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
