Question about HP LaserJet 9050mpf Printer
HP 9050 MFP ''scanner lock Check cables'' message.
During machine boot, I get a ''scanner lock check cables message''. Machine still works as a printer.
  • Paul Douglas
    Paul Douglas May 11, 2010
    If you can print an event log that woul be helpful. An event log give a history of error messages and can help in diagnosing your problem.
SOURCE: plug and play error hp laser M1120 MFP during installation
Please check the minimum requirement in the user manual.Read it carefully and try to install it again.
Posted on Jul 14, 2009
SOURCE: Check Cables. Check Scanner Lock. Cycle Power.
the problem is the cable in the scanner's mainboard
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: Scanner Problem HP 1005
for resolve this error you should only change the flatbed scanner wiht a new one. this error is hardwere issue.
by.
M.R.Atyabi
Posted on Jan 26, 2009
SOURCE: dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Posted on Jul 20, 2009
  • 3 Answers
SOURCE: error message on display of hp m 1005 mfp
HELLO
Posted on Jun 03, 2010
4690 MF Printer displays the following message:"SCANNER MOTION ERROR, CHECK SCANNER LOCK"
I would open up the scanner and check to see if it can move, When you turn on the machine does the scanner try to move before the code shows up.
Feb 18, 2015 | Konica Minolta Office Equipment & Supplies
Where is the sensor lock switch?
The scanner lock is situated at the left side of the flat bed scanner. switch it to UNLOCK.
Sep 04, 2014 | Oki Brand Oki MB480 MFP Multifunction...
Where do I plug in the cable from my Brother DCP130 PRINTER into my PC.
Using both hands, use the plastic tabs on both sides of the machine to lift the scanner cover until it locks securely into the open position.
Insert the USB cable into the USB socket marked with a symbol. You will find the USB socket inside the machine on the right.
Carefully route the USB cable through the trench and out the back of the machine.
Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
Turn on the machine by connecting the power cord.
Aug 13, 2012 | Brother DCP 130C All-In-One InkJet Printer
When i turned on my machine always initializing on screen
Turn off printer,remove right cover, pulled out Flat bed scanner head cable on formatter(see the location as shown in snap)secure the cable not to touch any ware, switch on the printer check the error, error persists same replace scan formatter, if other error,check scanr head driving mechanism any breakage replace it or replace entire scan head assm.
Oct 04, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Thanks, my HP LaserJet 9000MFP is requesting for cable check it say check cables. check scanner lock. cycle power
This error is an indication that the system is unable to move the scanner. This usually happens on new units when someone forgets to unlock the scanner before switching machine. If the printer has worked up till not and just started doing it then there is a good chance that the scanner has failed and will require service. If you just moved the machine then check the scanner locks and make sure the cabling is all connected.
Aug 09, 2011 | HP LaserJet 9000mfp Printer
I keep getting error U043 even tho I know that the ink cartridge is missing. However, I only need to use the scanner and am unable to get to the home menu because the error message won't go away. How...
Got a reply from Canon support as below.
During Boot Sequence of the machine, one of the checks performed by the machine is presence of Ink/toner Cartridge and the minimum quantity available in it to start up.
When the machine fails to get the signal of Ink availability, it stops the Initialization Process and an error code is displayed
Since the machine is an ALL-IN-ONE, it cannot perform any of its function, had it been exclusive Scanner the Boot Sequence would have been different.
Jun 18, 2011 | Office Equipment & Supplies
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
Hp laserjet 9050n appear disk not initialized .how to solve. thank you.
Turn off printer
Press and hold PAUSE/RESUME(START on MFP)
Turn on printer
Keep holding the PAUSE/RESUME or START until all 3 error lights light
Release the buttons
Press LEFT ARROW(5 button on MFP) until INITIALIZE DISKS appear
Press the CHECK(6 button on MFP)
Wait for printer to READY
May 11, 2011 | HP LaserJet 9050 Printer
My Hp Laserjet M1120 MFP showing message "Scanner Error 6"
switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required
this is work on 3055
so i think this work on your printer
Jan 04, 2011 | HP LaserJet M1120 MFP All-In-One Printer
HP LaserJet 9050mpf Printer Logo
1,107 people viewed this question
Ben Johnson
