Question about Whirlpool GEW9250 Electric Dryer
Dryer won't start cycle. Sensing light turns on and it beeps then
I don't know if it's a blown fuse or what. The dryer will allow me to pick a setting, shows the minutes but when I press start it beeps several times,(I think 3), the the sensing light is lit and it just sits there.If this is a fuse, where is it and can I replace it myself? Thank you!
  • angelsdemon Jan 09, 2009
    I have a whirlpool duet. The dryer won't turn on. When I try to start it, it allows me to set the cycle I want and the time but then it beeps 2 or 3 times and the sensing light comes on. This same problem was fixed by a repairman before and it only took about 5 or 10 minutes. I was thinking it might be a fuse. The suggestion/solution I received is not going to work. I've already tried to unpluggin the dryer, turning it off and flipping the cicuit breaker. I also do not believe the circuit board is bad or the computer board is bad since, as I said, the repairman was able to fix it so quickly. I just don't want to have to oay him another $80 to do it!
    Master:
  • 623 Answers
Unplug the unit and take the back off. Down towards the bottom, near the exhaust connection, you will find a small, white thin plastic part with 2 blue wires connected to it. Remove the wires, put them together, wrap with electrical tape, and then plug the dryer in and see if it runs then
Posted on Jan 09, 2009
  • Whirlpool Master
  • 19,396 Answers
Try tripping the circuit breaker, or unplugging appliance power cord for few minutes.
Give me the dryer model, so that I can explain the fault.
Posted on Jan 05, 2009
  • Ginko
    Ginko Jan 05, 2009
    Try first unplugging ower to rest the dryer. If that does not work, do the following.
    Check first thermal switch and also ensure door switch is not stuck.
    Three beepos on whirpool means one of the following:
    1) Control board bad.
    2) Touch pad bad.
    3) Control board and touch pad bad.
    You can find diagrams and replacement parts here.
  • Ginko
    Ginko Jan 09, 2009
    hi there, what was wrong with my solution , you refused my support, I will be grateful if you can tell me the reason .
    Thanks.
  • 115 Answers
First you need to take off the bottom panel, using a 1/4 ” socket to remove the two screws that are on the bottom front corners of the dryer. I propped it up on some 2×6’s to get easier access to the screws and make it easier to slide the bottom panel off. There is a thermal fuse that shorts out if the dryer outflow is too hot. This prevents you from destroying larger more expensive components, and all you have to do is buy a $10 fuse. The fuse is located behind the blower casing, which you can reach around if you take off the bottom panel. It is a white flat plastic piece, about 1×1′, with two connectors coming out of it. It is pretty well centered in the dryer by the blower. To check if it is good, check it’s resistance after unplugging it from the system. It should be darn near zero. If it is open (infinite resistance), you have melted the fuse and need to buy a new one. Just take it out with a ratchet and don’t lose the screws. Make sure you clean out your dryer vent, as restricted flow because of lint is generally the cause of overheating. also check your wires where your cord hooks up to the dryer you might have a burnt wire only getting 110v
F25 sensing light on
call a repairman
Jun 14, 2015 | Whirlpool Dryers
Duet dryer wont start beeps and sensing lights up!
Its likely your thermal fuse is out.
Disconnect the power! Remove the lint filter screen. Remove the two screws from the bottom flange of the toe panel. Pull the toe panel out at the bottom, pull down, and remove the panel. Remove the screw from the lint duct bracket and remove the bracket. Remove the two screws from the lint duct and remove the duct.
Then you will see the white thermal fuse on your blower wheel housing. You can jump it with an alligator clip or take the wires off the thermal fuse and use electrical tape to tape them together to see if it comes on. DON'T LEAVE IT JUMPED TO RUN A CYCLE, order a new one.
Here is a the part.
Oct 20, 2012 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer GEW9250 which has all panel lights light but when you push the start button it beeps once and the sensing light is on and it doesn't start. I changed the Thermal fuse...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Dryers
Dryer will not start cycle
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Feb 18, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Cabrio Dryer Wont go past sensing light when I press start. The door is tightly closed and the filter is clean. It just won't even try to start it just just beeps once.
my dryer sensing light was on and dryer would not start, we replaced the sensor fuse and now it works the fuse is in back of dryer close to the bottom on the left hand side very easy to replace cost $11.00 by the way don't call whirlpool they have no clue, wanted to send repair man out to fix it.
Nov 04, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Check the following:
Is the power cord plugged in?
Has a fuse blown, or has circuit break er tripped?
Was a regular fuse used? Use a time-delay fuse.
Is the dryer door firmly closed?
Was the START button firmly pressed?
Is a cycle selected?
Mar 07, 2009 | Whirlpool LGV4634JQ Gas Dryer
Dryer wont turn on
Ours was doing the same thing you would hear a click and nothing but the sensing light. I found the thermal fuse to be blown Part #3392519. Easy to get to through the front cover under the load door. I went ahead and vacuumed and cleaned out the inside and vent tube.
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer wont start
Commonproblems...blown house fuse, broken belt ( on some models )...door switch...*thermal fuse open (venting needs attention )...broken or burnt wire....timer....motor, in order from mostcommon to least common. * If you find a blown thermal fuse, always clean, change, adjust the ventingsystem and vent hood first, then it is often a good idea to replace the operatingthermostat at the same time. This is a picture of some modernthermal fuses.
I hope this will solve your issue.
Good Luck
If my solution proves useful please accept it.
Regards
Arjun
Sep 07, 2008 | Whirlpool GEW9200L Electric Dryer
Dryer quit running in mid cycle
It's the thermal fuse and it's easy to install if you have a front loader just take the kick panel off in front, make sure you remove the lint filter and the cover that goes up to the lint collector and you will see the thermal fuse. Make sure you unplug before doing this. Take the two screws out of the bottom of kick panel and than use a putty knife and push down and the panel will come right off. Hope this helps you out.
Jan 06, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
237 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
