Question about GE Cafe CGS980S Kitchen Range
GE Cafe CS980Sn1 Kitchen Range - GE Cafe CGS980S Kitchen Range
4 Suggested Answers
brnspncr
  • 67 Answers
SOURCE: WHERE CAN I FIND A USER MANUAL FOR MY GE CAFE
Try: www.retrevo.com/s/GE-CGS980SEMSS-Ranges-review-manual/id/6683ag412/t/1-2/
Posted on Jul 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE Spacemaker JMP28 Electric Kitchen Range F1 error message
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
(*UJ
Posted on Oct 01, 2010
  • 17 Answers
SOURCE: ge range adjustable feet
you have to get them from GE
Posted on Sep 21, 2012
Ge cafe stove bottom oven not working
Is there 120V to the igniter? If the voltage is there, but it is not glowing, replace the igniter... GE Range Stove Oven Igniter WB2X9998
Jan 02, 2016 | GE Cafe CGS990SETSS 30" Free-Standing Gas...
Converting cafe range to lp
http://www.davesrepair.com/DIYhelp/RngNAT-LPconv.htm
once you have the conversion kit, here is a simple procedure to follow to convert your range. Most conversion kits come with step-by-step instruction sheets. Also, use a piece of black electrical tape and fold it over the edge of the socket you'll use so that part of the tape is inside the socket. This will maintain a hold on the orifice when removing it so you don't drop it inside the stove top.
Jan 18, 2014 | GE Cafe CGS980S Kitchen Range
Ge range adjustable feet
Sep 20, 2012 | GE Cafe C2S980S Kitchen Range
Oven shuts off while baking. No error code, it just shuts off and none of the buttons work on the GE Cafe range.
I have the same problem. GE repair man replaced the electronic control panel. If anything, the problem is worse. Does anyone know what ACTUALLY makes this range shut off as it gets up to temperature while baking? I don't really want to pay the repair man to fumble around debugging this.
Aug 24, 2010 | GE Cafe CGS980S Kitchen Range
I need a thorough description of this kitchen range GEC2S980S; number of burners, size, available colors, price, etc.
Visit the ge appliance web site and Key in your model number C2S980SEMSS and you will get a complete breakdown of all specs and features as well as the ability to look at specific dimensions and product installation the guide.
Try this link:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=C2S980SEMSS
Aug 18, 2010 | GE Cafe C2S980S Kitchen Range
GE CAFE dishwasher was installed and I can see the hindge at the bottom of the door. Can it be installed deeper in the cabnit
if it was installed correctly you should only be able to see the hinge uif you were looking at it on a downward diagonal
Nov 16, 2009 | GE Cafe C2S980SEMSS Stainless Steel Dual...
GE Cafe CGS980S Kitchen Range Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
