RCA wont charge
Rca sc2002 is new and it wont charge ( tried 3 hours ), PC says USB has i/o error.no display on LCD.
  • 916 Answers
There is a ton of things that you can check,
Boot the computer and go to the BIOS or SETUP.
Make certain that you have enabled the USB. Save and Exit.
Have you tried all the USB Ports in the back,of the PC.
You need to confirm if you have installed the appropriate and most update USB firmware driver for your motherboard.
Go to inspect the Control Panel, system, device manager.
Posted on Jan 07, 2009
    Genius:
  • 1,199 Answers
Try another usb port! also you may have gotten a defective battery!
  • 19,396 Answers
If it has IO error check the connection cable, if you use no cable, then the USB connector may be defective, test it on a different computer.
  • Ginko
    Ginko Jan 07, 2009
    If there is no display then the unit may be faulty, this MP3s have an internal battery, if you are lucky it is just the internal battery that must be replaced, if not, then the player is gone.
    By the way, when it is the battery, the unit should at list blink quickly when connected to usb. If you use a cable, check te cable, that is the most likely. If not, the unit is probably faulty, and must be taken apart and tested.
    The IO error is just because the unit is off, the connector may be OK
  • Ginko
    Ginko Jan 07, 2009
    If the unit is new this is quite weird, probably it is a factory fault.
    If the RCA never started call the phone number listed on the owner manual, and ask them instructions on how to proceed, they will send you a replacement.
    If you purchased from a local seller, go back to the seller and ask replacement.
How do I set the time on a RCA USB Charging Clock Radio RC142?
Setting clock manually
1. Press and hold Set Time to enter the clock setting mode.
2. Press HOUR+ and MINUTE+ to adjust the time.
• Press and hold to adjust the time value quickly.
• The digits on the display ? ash in clock setting mode.
• The clock is in 12 hour format. The AM or PM indicator will illuminate to indicate the current time setting.
3. Press Set Time again to save the time setting
RCA RC142 User Manual General Controls
Mar 18, 2016 | RCA RC142 AM/FM USB Charging Clock Radio
Just got it new.....screen won't go past rca logo
Why wont my rca tablet load past the RCA logo screen? - I ...
www.askmefast.com > Consumer Electronics > TVs > Tablet
Laptops & Notebooks .... My rca tablet wont go past the first logo screen and i have factory reset it and ... Some how the factor reset button on the back of my rca 7in tabletgot pushed and ..... Rca tablet will not play games it just goes back to home screen ....My rca 7 tablet is stuck at the main screen and it won t go any further.
my rca tablet won't turn on I tried charging but it's not working ...
www.tomsguide.com/forum/id.../rca-tablet-turn-charging-working.html
Dec 15, 2015 - 12 posts - ‎10 authors
My rca tablet isn't working I tried charging it but it's still not turning on ... Hold them both in this position until you get a menu on the screen. .... I've repeated this attempt to turnit on it just flashes on the battery logo with an exclamation point ... SolvedMy Asuslaptop model Q551L won't turn on or charge what ... Tablet keeps turning off - Battery
Nov 16, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
RCA tablet no power-up - Power Up
Mar 30, 2015
Help! My tablet won't turn on! what do I do?! - Asus
Nov 5, 2013
More results from www.tomsguide.com
Dec 25, 2015 | Computers & Internet
Rca opal 4gb M4304-A has completely stopped functioning
Wow, I didn't realize so many people were having the same problem I was having. First try re-installing the firmware for it. Since your computer won't recognize it you will need to download the software, then you will have 2 boxes pop up. One is the install instructions and the other is the actual program install. You will have to hold down the play button on your player while you plug it into the computer. DO NOT RELEASE THE BUTTON UNTIL THE PROGRAM SAYS "INITIALIZING".
It should work fine once you do this. I spent 3 hours going through RCA's website before I came across this step.
Nov 22, 2009 | RCA M4304 Digital Media Player
My rca mp3 wont turn on
1 have it into usb device
2 hold down the play button.
3 update the firmware from RCA website.
Jan 10, 2009 | RCA M4204 MP3 Player
Mine wont turn on
On the back of the the mp3 player is a reset switch.
Hold that down about 15 seconds.
If that does not work go to the RCA website.
Download the latest firmware.
Plug mp3 player into pc.
Install the new firmware.
Keep it plug to computer for about 1 hour to charge the battery alittle.
Dec 27, 2008 | RCA M4204 MP3 Player
My rca mp3player m42series screen will not show anything
You need to charge it for at least 3 house.
To charge the battery. Hook to usb device of your computer for about 3 hours.
Dec 25, 2008 | RCA M4204 MP3 Player
RCA OPAL M4002 mp3 player
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 20, 2008 | RCA OPAL M4001 MP3 Player
Software Installation Disc Problem for RCA 512mb ModelTH1100A
when iam connecting rca emusic1 digital player to the computer having windows xp sp2, the computer freezes and after some time windows displays error report like this"windows - delayed write failed" can u suggest me how to open the rca through usb..
Dec 25, 2007 | RCA eMusic MP3 Player
Flash mp player (rca m4002)
Reset first.
If fails, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 23, 2007 | RCA OPAL M4001 MP3 Player
21 people viewed this question
 Grubhead
Grubhead
