Question about HP Office Equipment & Supplies
Officejet 4620 series GOES OFFLINE
Worked fine a couple of weeks - now is temperamental, goes off line. I manually make sure settings on the printer say online, says OK. try to print - the printer info says print job cancelled, printer offline.
bravsman
  • 94 Answers
SOURCE: "printer is currently off-line. offline" use a mac
check the usb cable of printer try to reconnect it and make sure you use usb port in your printer properties
Posted on May 25, 2009
APremkumar
  • 564 Answers
SOURCE: Printer offline HP 4500 series wireless.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on Mar 31, 2009
callonafo
  • 174 Answers
SOURCE: Print jobs go through the queue but nothing prints
Maybe you should uninstall software for the printer the restart your system again then reinstall back the software for the printer, the problem maybe as a result of the configuration on your system. after reinstalling try to print out a tested page to see if the problem still persist. Thanks
Posted on Sep 25, 2009
  • 739 Answers
SOURCE: HP C4680 Goes Offline
Hi
Just a thought, did you use the HP CD that came in the box?
Go to Apple's website and look under the support - downloads section. You'll find a mega-sized download of up-to-date HP drivers. Download it and install it.
Then open the print and Fax setting in system preferences and remove the existing HP printer, You should then have no printers listed in the printer box.
make sure the printer is connected to the macbook and switched on and then use the Plus symbol to add a new printer. In less than a moment your printer name should appear in the empty space. Select it and wait. You should then get a thing saying 'Print Using...." It should fill in automatically with info about the driver being used.
Do what ever it asks and then close the window and see if you can print without the earlier problems.
Posted on May 04, 2010
  • 8404 Answers
SOURCE: My hp 4300 series printer goes in offline mode and
Delete the printer and reinstall it ...
Posted on Jun 10, 2010
How do I get my printer 4620 back on line
your Q is too simple. Try reload the driver to this printer to see if the problem is solved.
Jan 12, 2015 | HP Officejet 4620 e-All-in-One Printer,...
After fixing a paper jam, my printer will not print or scan from the computer. Say computer not found. what do i do?
while on jamming the machine the USB cable may have come on plugged check that first.be sure not only to check where it goes into the computer but more importantly where it went into the printer.if that doesn't work try rebooting both devices.
Jul 17, 2014 | HP Officejet 4620 e-All-in-One Printer,...
A couple times a week my HP Deskjet DI660 printer goes 'offline'. When this happens a message appears 'new hardware found'. And my printer will not work until I have disconnected the the...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 26, 2011 | Office Equipment & Supplies
It says that my officejet 6210 is offline when i go to print, everything is plugged in though and ive restarted it a couple of times. Was working fine before and now its not.
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
And:
Go to Start-->printers and faxes-->right click on the printer-->properties-->make sure it
Jan 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Printer is offline cannot get it on line
hELLO THERE:
if you go to the file at the top left of the screen click on it and look towards the lower part of the file and you will see work off line and if this is checked uncheck it also make sure that when you set up the printer originally that you set it up for online use.
Aug 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP OFFICEJET PRO 8500 GOES OFFLINE
on hp.com they have driver updates try just updating the driver
Jun 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer goes offline
Set IP of printer manually and make sure AutoIP is off. Printout user settings to ensure.
Dec 11, 2007 | Brother MFC-7820N Printer
1,415 people viewed this question
Seeker5211
Seeker5211
