Mc361 oki paper jam - Office Equipment & Supplies
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
SOURCE: OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
I've just cured the same issue.
Inspired by MCS-IT, I fed a sheet of paper into the paper path (printer over the edge of the desk) popped open the front cover and manually drew the paper through by turning the cog wheels. Voi-la (sorry French spelling not a strong point) a small piece of ripped paper was forced out!
Posted on Feb 21, 2009
  • 260 Answers
SOURCE: oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Posted on Apr 09, 2009
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
  • 9 Answers
SOURCE: Oki C9300 - paper keeps
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Posted on Oct 31, 2009
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
How to check ink levels on oki mc361?
Press the STATUS button on the operator panel. This will display the toner levels on the LCD screen
Nov 26, 2013 | Oki Electric Industry Office Equipment &...
En la pantallade la impresora oki B4350 me marca error 134
Tengo una Oki mc361/mc561 me da error 134 como puedo solucionarlo
Aug 26, 2011 | OKI B4350 Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Oki c5200 paper jam
I used tweezers after I took every thing that could come out--out.
Feb 19, 2009 | OKI C5200n Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
Aug 22, 2007 | OKI B4300 Led Printer
101 people viewed this question
k24674
