Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool Generation 20004 Oven Model G2P62F
Help please! I went to switch on the oven tonight but no display - then I switched it off at plug and on again (troubleshoot in manual!!!) light came on oven came on and went off again - tried it on grill setting and same thing happened - now have no display but it did come on again earlier and read "Stop" on display but seems to come on and fan works for short time and light inside is on but it then all goes off again!!!!!
I have viewed this site and I think it points to thermal fuse problem but not sure where to locate this as oven is built in - have undone panel at back where fan is housed and nothing in there? Any ideas, please would really be grateful!
Regards,
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Posted on Jan 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Whirlpool AKZ451 oven not working properly
If the fan is still working ,then you need a new oven element fitting, it will have blown, there by causing trip to operate.
Plz rate this solution .
Thanks.
Posted on Dec 12, 2008
SOURCE: Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Posted on May 29, 2009
jumptrout51
  • 3361 Answers
SOURCE: E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Posted on Jun 12, 2009
The fan on my Whirlpool G2P62F electric oven is glowing red but not turning.
The fan is seized and is now working as a heater. It needs replaced. Try nudging the fan blades round it may loosen up.
Sep 03, 2014 | Ovens
Electric range/oven switched from bake to self-clean without my help!
Good Afternoon Mr Oliver!
Often, if Whirlpool oven starts to do things on its own.. the touchpad might be failing or faulty. Keys fail and short, meaning they think they're being pressed when they actually aren't. Do you have the model number of you oven?
May 17, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Im getting F13 on my oven display when trying to use it?
Sabrina I do not see an F13 Error Code for Whirlpool, Try unplugging oven for a few minutes and then plug or switch power back on from breaker and it should reset. Also send the exact model number located inside your bottom drawer door or oven door. Here are all the codes listed for Whirlpool=> Whirlpool Fault Codes You also can find your user manual here=> Whirlpool User Manuals and model number Locator's here=> Model Number Locator's I have spent a lot of time trying to help and will be happy to assist you if you have more questions, Thanks, Sea Breeze
May 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
GJP85200 Whirlpool Oven display went dead
First you need to check if a supply is available to the machine. The safest way to do this is with a non-contact voltage detector. You can get one for around £10. (Also called volt sniffers by some) If you have an electrical supply to the machine I would call for service, use yell.com to contact your most local cooker engineer. If there is no supply you need to check back at your fuseboard to find out why.Have you reset all the trips?. Is there a spur with a fuse in it between the cooker and the fuse box?
Apr 04, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven wont come on
YOU NEED A LOCK SWITCH, TRY CUTTING OFF OVEN FOR A WHILE AND PLUG BACK UP
Jan 01, 2008 | Whirlpool RBS245PDS Electric Single Oven
Display
Need new electronic module
Jun 14, 2007 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
79 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
