Question about RCA F20632SE 20" TV
I HAVE A RCA TELEVISION, MODEL F20632. I CANNOT FIND THE MANUAL TO HELP ME SET UP MY VCR. I HAVE A 4-PLUG VIDEO CABLE (YELLOW, BLACK, GREEN AND RED). CAN YOU TELL ME WHICH CONNECTIONS ON THE TV I NEED TO USE? THANK YOU
  • ksandbs1014 Jan 05, 2009
    I AM TRYING TO LOCATE A MANUAL FOR THIS TV (RCA MODEL F20632) AND CANNOT LOCATE A LOCATION . DOES ANYONE KNOW OF A LOCATION I CAN DOWNLOAD FOR FREE.
  • 905 Answers
The yellow rca input jack( not the output one ) is for video in (by itself ) and the red and white rca jack inputs are for the right and left audio that is also required when using the yellow video jack
the red and white audio jacks are also required when using the component video inputs ( BLUE , GREEN & RED ) rca jacks
but only one type of connection is required ( yellow video jack , red and white audio jacks ) or ( the blue , green and red component video jacks and the red and white audio jacks )
you will need the yellow video input and the red and white audio inputs
Posted on Jan 05, 2009
  • jason Jan 05, 2009
    why would you give a thanks for trying , when you asked, "which connections on the tv do i use? " and then say " I'm trying to locate a manual "
    I have a link to your manual , but would appreciate it if you gave a fixya rating for answering your question ( since that is the connections you will need to use for your vcr( combo?) to your tv
    Genius:
  • 1,199 Answers
Yellow will go into yellow....red into red....and make black go into white VCR output to tv inputs! This should do it!
Please rate my answer and help keep this site FREE!
Thank You
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
Having trouble with direct connection from VTM190A VHS to an old RCA TV- have red cable to red and yellow to yellow and both units reading channel 4, but still only static. Obviously don't have something...
Channel four on the television wouldn't be correct when hooking up with the yellow red and white RCA cable. The television should be on video/aux/input etc. You should see a button for you to do that on the tv, on the tvs remote control, or within the tvs menu.
Apr 22, 2011 | Hitachi VTM190A VHS VCR
Help
Hi, Flat panel television instruction manuals are not very easy reading material, there are many connections on the back-you need to plug in some sort of input-always coming from the " out to T.V." of another device. Cable coax's are most common-the cables aren't very flexible that's one way to tell them apart from an RCA cable-usually with red, white, yellow,green and blue colored ends. The red, white and yellows are what we'll focus on for now-the yellow's are for a picture-connect them from an " out to TV" to " video input" on the back of tv, then for sound likewise- red and white colored from an"audio out " to "audio in " if coming from a VCR-you may use the rather un-flexible " screw on" coax connector-same if coming from a satellite/cable box-some satellites require tuning tv channel to # 60 for a picture-other wise it's channel 3 or 4. although you will get a better picture using yellow, red & white rca cords. I hope this has been of some help, prodzilla
Mar 31, 2011 | Televison & Video
Hi. I have an old RCA tv, model # T09081bc. I was hoping to hook up my Playstation 2, but the best result I've gotten was a black screen. I have two different cables for it, one that plugs into the cable...
After you plug the Yellow (video),Red (audio 1) and White if Stero (audio 2) turn the Playstaion on, now turn to chanel 3. does it work? if not look for selector on TV (video input,aux) or use up-dn chanels until you get playstation screen.You can also plug the round antenna cable from TV to unit and set TV to 3 or 4.Good Luck.
Sep 05, 2009 | RCA T09081 9 in. TV/VCR Combo
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Taping
If there is no coaxial cable input on VCR, then it should work by RCA cables. Which is the Yellow , red/white cables. On the back of the VCR. Take a set of RCA cables Yellow for video, red/white for audio to the VCR output.Then do the same to the Television input. Next use the television remote to turn the TV to Video input this will allow you to view what's playing on VCR. Then take another set of RCA cables and reverse the first setup. Attached Cables to VCR input and cables to TV Output. This will allow you record what's on television. Now make sure the cable is screwed to coaxial cable input on television. This will able you to access cable programming on television, view vhs tapes, and record programming directly from television.Good Luck
Oct 12, 2008 | Televison & Video
No movie picture
If you want to record from cable to your vcr the usual configuration is either cable to cable box, cable box to vcr, and vcr to tv. If you want to get rid of the snowy pictures, you can plug the cable box directly to the tv and separately to the vcr, and you can also plug the vcr into the tv. but the tv has to have two inputs
the best configuration will be the black, screw in, coaxial cable from the cable box to the television and the red, white and yellow RCA plugs from the cable box to the vcr in.
then the vcr our red whit and yellow cables to the back of the tv.
To watch vcr, switch the tv to video mode
to watch cable, switch tv to channel 3 or 4, depending on the cable service.
please let me know if you have questions.
Ken
Jun 24, 2008 | Goldstar Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Televison & Video Logo
209 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
