Question about Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face
When turning lights on, the light, then deep end immediately shuts off, and shallow end stays lit. Could this be to the 40 degree water temp or something else. They both light up eventually.
5 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: pilot did not stay lit
Your problem is the pilot generator where the flame is by the burners. This needs to be repalced. That is what is causing the pilot to go out and not start. It is a flame sensor and also tells the gas valve when to release more or less gas.
Posted on May 28, 2009
  • 12 Answers
SOURCE: hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Posted on Jun 25, 2009
  • 7 Answers
SOURCE: my navigator seems to stay primarily in the deep
Could be several things. If no blockage at inlet hole, feet are in good condition, springs in place and moving freely, etc., I would suggest too little suction. Use the gauge that came with the unit to check for acceptable level. If you don't have that, it will just be trial and error to get it right. Unfortunately, you can't set these once and expect them to remain functional. Suction is always changing depending on filter pressure (blockage), skimmer baskets full, etc..
Posted on Jul 05, 2009
jharwell668
  • 640 Answers
SOURCE: new navigator stays in deep
If your filter is placed toward the deep end of your pool, it could be that the pool cleaners hose is too short to reach the shallow end. You might want to test it and add more hose if necessary. It could also be a steering failure. There are a couple things to check if this is happening. Check and clean the rear screen. Make sure that your cone gear is free and rotates smoothly. You might also need to clean, repair, or replace your gearbox.
Posted on Jul 25, 2011
Bakers pride deep fryer will only stay lit for couple of minutes and then shut off
Hi there!
Normally hi limit sensing bulb is thicker and shorter than that of thermostat.
Try tightening all wire terminal crimps and connection.
Regards.
Feb 05, 2013 | Imperial IFS40 Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Pitco Fryer will not light up
Check the thermopile, it must be free of dirt or soot so that it can absorb enough heat from pilot flame and in turn can generate the right amount of voltage to energize pilot and burner coils.
Check also the gas pressure, it should be of standard as required on the unit's nameplate.
Apr 15, 2010 | Pitco Frialator SG14 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
May 31, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Imperial fryer IFS-40
I had a very simular problem. My fryer would do exactly as you described, but sometimes the pilot light would stay on until the burners tried to re-ignite and then it would go out.
I finally had to call the gas company. They took the pilot light apart and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 18, 2008 | Imperial IFS40 Deep Fryer
Problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Nov 10, 2007 | Imperial IFS40 Deep Fryer
Hayward 12v LED Color Logic Pool Light -100ft Cord - SS Face Logo
162 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
