Hi. I have an old MediaCenter Pioneer KH-8855. I tried to repair the turntable. Got the motor and made a metal base to fix it. But the motor does not have hid own pulley. The pulley I have is another, high, so I had to get down the motor. It is not good speed. Where can I get the proper pulley? Any idea? Thanks from Spain.
fire sine
  • 382 Answers
SOURCE: Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Posted on Oct 28, 2007
djproaudio
  • 515 Answers
SOURCE: JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
SOURCE: Pioneer PL-570 turntable (c.1973)
pioneer PL 570  tone arm drops and turntable shuts off,  what gives?
Posted on Jan 16, 2009
SOURCE: Where to get 12 volt power supply for Pioneer PL-203AZ Turntable?
+ is on center pin, and the current consumption is low, not more than 200mA. A 12V wall-wart will do fine.
Posted on Dec 23, 2009
dunnbiker
  • 8546 Answers
SOURCE: Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
Posted on Feb 15, 2010
Hi - I have a CDJ 700S which skips intermitantl...
Hi Tony, you should also, explain how old is your pioneer cdj 700s. I hope you have done all what you could.
May be your player have lived his life and its leaser needs to be replaced.
Djajay
Djajay@inbox.com
May 19, 2010 | Pioneer CDJ-700S Turntable
Pioneer turntable PL443 hangs in endless start/stop loop
there are 2 little sheet metal parts mounted on the big center spur wheel. The upper sheet metal part is moved by the lower one. To do this, there has to be some friction between both sheet metal parts, but not to o much.
Dec 30, 2009 | Pioneer Audio Players & Recorders
I have an old Pioneer stereo auto turntable PL-5.It is rarely used and worked fine until my grandson started to turn the turntable by hand and I think backwards.Now it speeds up and races.Can this be fixed...
if the speed is constantly fast the drive belt may have ridden up on the top part of the motor pulley.inspect and refit.if the speed varies check operation of 33/45 switch.
Dec 15, 2009 | Pioneer Audio Players & Recorders
What does error 7201 on the mk3's mean?
You can't fix. THis is a disc error code. This means that the Traverse assembly is damaged in some way. Only way to repair is to replace.
I would suggest contacting a qualified service technician for assistance with this.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 02, 2009 | Pioneer CDJ-800MK2 Turntable
My pioneer PL990 turntable, the pitch wavers.
try cleaning the inner ring on the underside of the actual turntable platter and also the motor spindle using isoprynol alcohol or use neat clear spirits like bacardi/vodka with cotton wool etc. if black residue comes off either the platter or the motor spindle that will be residue from the old belt that could cause the fluctuation in speed? good luck.
Jul 10, 2009 | Pioneer PL-990 Turntable
I have just unearthed my pioneer music system from the loft (PL-Z93) and the turntable doesn't revolve when I pick up the stylus arm. It also needs a stylus but there's not a lot of point if I can't get...
If you had it in a hot loft, the belt may not be any good. Good news is they are fairly easy to get.
if you lift the rubber mat off the turntable platter you should find two holes in the platter. If you rotate the platter, you should be able to find the motor capstan that the belt will go on. lift the platter off and you should be able to see where the belt will go on it on the underside. put the belt on the platter, keep tension on it with a finger thru one of the holes, place it back in the base and pull the belt over the capstan. if it's too loose you'll need a new belt. Find an electronics supply store and they should be able to get you one. to save you time, Radio Shack probably can't help you.
Sep 13, 2008 | Pioneer Audio Players & Recorders
Cmk
Your loading motor is damaged. You'll need to take it to a service center for repair and replacement.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Aug 30, 2008 | Pioneer CDJ-800MK2 Turntable
The CDJ won't load the disc!!!
You have to get it repaired,no quick fix im afraid.
email: info@audiovisualservices.info for all dj equipment repairs.
Thanks.
Aug 23, 2008 | Pioneer CDJ-800 Turntable
Motor for pioneer Pl 120 turntable
There are only three possibilities:
1) Find a scrap unit somewhere and salvage the motor.
2) Find an old Pioneer dealer that still has old stock lying around.
3) Get lucky and find one on Ebay.
Dan
Mar 28, 2008 | Audio Players & Recorders
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
69 people viewed this question
 Grubhead
Grubhead
