Question about Canon Office Equipment & Supplies
Cannon IR 5055 ERROR E000532-8002
The copier just started brining this error up. It has something to do with the stapler and limited functions mode. I can turn on limited functions mode so the copier will work, but it won't let me use the staple feature. It says finisher is not woking... or something like that.
MediaMan85
  • 163 Answers
SOURCE: Need for Cannon Digital Copier & Printer ir2016j driver
Please check http://www.usa.canon.com/html/download/im20162020.html
and see if the driver you are looking for is located there.Please note this is for USA models.
The Europe site is
http://software.canon-europe.com/products/0010277.asp.
Hope this helps....
mediaman85@mchsi.com
Posted on Jan 23, 2008
  • 523 Answers
SOURCE: installing staples in a Canon imagerunner 5055
Open the finisher door and you will find the place, it is in the front side. Regards
Posted on Mar 02, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
I have error sc 00001-01 in my copier canon ir-5055
Check the connector of each thermistor,replace if neccesary.After fixing the problem reset the error in service mode:COPIER<FUNCTION<CLEAR <ERR,and turn machine OFF
Jan 14, 2015 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
I have a cannon ir 3300 machiene and occured a problem with a error code e000000-0000 please help me out to remove this problem my technician has asked me to change the filament which is worth 12000.w
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
Feb 17, 2014 | Cannon Office Equipment & Supplies
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
E000532 0001 on cannon ir c5030
This is normally a finisher error code, normally the stapler shift error, depending what sub code after the 532 code display, remove finisher to verified that the code goes away.
Feb 05, 2013 | Cannon Office Equipment & Supplies
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Canon ir 5055 has an error e000004-0010. how di I fix this?
This is a fixing error code - there is too much temperature difference detected by the thermistors. Mostly a error reset will take care of the problem. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. DO NOT keep resetting the code. There is something wrong with the copier that needs to be taken care before major damage is done to the copier. Good Luck
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
Code error of Cannon IR3300 E000006-0000
getfile.asp?rid=1258 November 7, 2002 getfile.asp?rid=3215 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS
Apr 29, 2009 | Office Equipment & Supplies
Canon IR 5070 Error
542 is a code for your finisher bins not moving or hitting something as the move... you have ti turn off limited functions mode under addinional functions common settings then turn off limited functions then turn copier off then on
Jan 02, 2009 | Office Equipment & Supplies
356 people viewed this question
old marine
old marine
