Question about Maytag Hardware & Accessories
No heat in dryer
Man came and said it was the timer needed to be replaced can that be why heat stopped? or do i need a heating element or new dryer?
  • Tripp REa May 11, 2010
    need mor info... gas or electric, model mfg.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • Maytag Expert
  • 90 Answers
If the dryer cycles normally, it is most likely the elements or some part of the controls. turn the dryer on and check the voltage at the elements, if u have voltage then the element is bad.
if no voltage or not enough voltage, then u need to follow the circuit back to see were it stops.
if its on an old fuse system 1 could be blown, this would let it run without heating. the relay that turns the elements on could be bad and not engaging, if all this checks out then the timer is the culprit.
if u need more info msg me please
Posted on Jan 12, 2009
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
My APT timer for my heating is not turning "as a clock"
Is this new installation?
If timer dial is not rotating, then timer is not wired correctly, voltage is wrong, or timer motor has stopped functioning.
If small motor used to rotate dial has gone bad, then replace timer.
http://waterheatertimer.org/How-to-set-timers.html
Add a comment with more information for possible follow-up
Mar 24, 2013 | Hardware & Accessories
My whirlpool dryer stopped heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0'0
Jan 17, 2011 | Major Replacement For Whirlpool Dryer...
My fridgidaire dishwasher leaves gritty and oily residue on dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 01, 2010 | Frigidaire Dishwasher Timer Assembly -...
Dryer runs but does not heat
heatman101
Sep 23, 2010 | Maytag Dishwasher Timer Assembly -...
I'm having trouble with the lower heating element not heating on my GE Electric Range. Its probably 10 + years old. The broiler element heats. Will I be able to replace the element or circuit board? ...
Most of the time it the heating element.
(recheck your model number)
Here is a good source for replacement part
http://www.partstore.com/Content/CategoryPages/Kitchen-Cooktops.aspx
Or directly to GE
https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=LANDINGPAGE&AppliancePart=Cooking%20Products
Dec 24, 2009 | General Electric Stove/Oven/Range Chrome...
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
Paragon 8145-20 defrost timer
I am not professional at commercial refrigeration, and can't answer your question directly.
However, you can see 8145-20 240V defrost timer wiring diagrams and manuals on following link.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
8145 timer is time initiated, and pressure/temperature terminated, with back-up time termination.
Jun 28, 2009 | Paragon 8145-20 Defrost Timer
I own a Maytag Dryer that has stopped working properly: Model LER6620PQ0 Serial MS3647251 Type DWJR-ELE-2406028-FM54 On all cycles, the timer moves until it is ready to stop. At that position, it...
Dear Paireyes,
Things that can stop electric dryer from heating are as listed: house fuse or breaker, heating element, burnt wire, thermostat, thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug
To check various points here are the simple tips:
  1. To check the thermal fuse - You can bypass the thermal fuse (just connect the 2 wires together) for testing purposes only.
  2. To check the thermal cut-out - You can bypass the thermal cut-out (just connect the 2 wires together) for testing purposes only.
  3. To check the thermostats for continuity - - You can bypass the thermostat (just connect the 2 wires together) for testing purposes only.
  4. To check the Element: Try removing element and physically looking at the element wire for a break in the wire.
Here is the link for the dryer and how to disassemble the dryer along with the images:
http://www.applianceaid.com/may-apart.html#common
Let me know if that helps. All the best :)
Regards,
Srinivas
Jun 23, 2009 | Hardware & Accessories
Hardware & Accessories Logo
91 people viewed this question
Top Maytag Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Maytag Hardware and Accessory Expert? Answer questions, earn points and help others
