Question about HP ProLiant ML110 Server
Layout of motherboard for a Proliant ML110
Hi Support
Thanks for looking into this.
I have swaped the motherboard in a Proliant ML110. Everything was able to be connected except the CN14 connector. Its a 10 pin connector and 1 of them is blocked off.
What I am looking is a pinout for this connector so I can split them out and connect them on the new motherboard.
Thanks in advance.
Morten Vendelsoe
Denmark
  • Michael
    Michael May 11, 2010
    Hello, Which generation of ML110 server is this ?
  • Rajesh Bhavsar May 11, 2010
    Pls confirm the issue
5 Suggested Answers
ted1430
  • 339 Answers
SOURCE: HP Proliant ML110 drivers required
Ge the Proliant Support Pack(PSP) as this will update all drivers at one time. If you haven't loaded an OS yet, get the SmartStart CD download. This will pre-populate the drivers on the server before starting the OS installation.
Posted on Jul 12, 2009
ted1430
  • 339 Answers
SOURCE: i need to download an hp proliant ml110 driver for window xp
HP does not support XP on their servers so you won't find appropriate drivers on their site under the ML110. The 110 is low end and in reality shares more in common with mid to high end PCs than othe servers though. Other than storage drivers you will probably be able to just let the XP install handle things.
For storage drivers you'll probably have to use the F6 option when installing and experiment until you find a driver that works. It's possible tha the Server 2003 driver will work but I wouldn't bet on it.
  • 33 Answers
SOURCE: ProLiant ML110 Server: i NEED WINDOWS XP dRIVERS FOR HP PROLIANT G3...
Why the Machine is not ment to use as Desktop try using windows 2003 server driver from cd supplied with it that will work for xp
Posted on May 07, 2010
f1delphi
  • 179 Answers
SOURCE: LAN DRIVERS FOR HP PROLIANT
You can download a proper driver according to your OS from here:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3577715&lang=en&cc=us&taskId=135&prodTypeId=15351&prodSeriesId=3577708
or
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3279679&lang=en&cc=in&prodTypeId=15351&prodSeriesId=501887&taskId=135
Posted on Aug 19, 2010
SOURCE: i need network drivers and video controller for hp proliant ml110
I NEED FOR THE DRIVERS SOUND CARD & VGA DRIVER
My Hp proliant Ml110 g5 server powers on, but shuts itself down while the OS is booting - win 2003 server
Perform a RAM test to check every section of the memory. It might be hitting a bad sector when it loads the OS.
Oct 18, 2011 | HP ProLiant ML110 G5 (444809-001) Server
I have a hp proliant ml110 server desktop. now i am install xp. so now i want to network and sound driver. how it will be get?
Click here You can download it from above link. Let me know if you need further assistance. Thanks for using FixYa.
Jul 11, 2011 | HP ProLiant ML110 Server
Ths screen displays ERROR,Expansion ROM not initialized-PCI network controller on Motherboard. Bus:04,Device:04,Function:00 how do i fix this? I am trying to install win 2003 server ,system not...
The ProLiant ML110 server with System BIOS Version 16 supports a total of eight IPL devices. Four IPL devices, such as the IDE controller and the floppy controller, are integrated, leaving support for four additional PCI IPL devices (i.e., PCI card plugged into PCI expansion slots); however, the ProLiant ML110 has five PCI expansion slots. Therefore, it is possible to configure the ProLiant ML110 with five PCI IPL devices (such as SCSI controllers or NICs) and exceed the limitation of System BIOS Version 16
The resolution to the problem is to update the System BIOS Version 17 which supports a total of nine IPL devices and five PCI IPL devices. Update the ProLiant ML110 server to System BIOS Version 17
i could not include the url for the download because you did not especify the generation of your server
but follow this link
1.select your server with the corresponding generation
2. select the operating system
3. from the download list select the bios update to a bootable usb or diskete
4.install the os
Oct 27, 2010 | HP ProLiant ML110 Server
ERROR: Expansion ROM is not initialized- PCI network controller on Motherboard. Bus:04, Device: 04, Function : 00 Secondly i have been trying to install win server 2003 on it, but i cannot seem to get...
i could not include the url for the download because you did not specify the generation of your server
4.install the os
I need windows server200 usb drivers for hp
Since I dont know which version you have, I assumed the ML110 original (see support.hp.com for other generations of this server)
also, i assume you are using server 2000 rather than 2003
After looking on their website, they dont seem to have the drivers you are looking for, you will need to look up either the usb controller (if it is an addon card) or the motherboard make and model (if using onboard usb ports) to determine the drivers you need.
With that information, I would be more than happy to help you find the drivers you need.
Thanks,
Mike.
May 16, 2010 | HP ProLiant ML110 Server
May 07, 2010 | HP ProLiant ML110 Server
HP Compaq ProLiant ML110 G4 Server Problem
how to load HP Compaq ProLiant ML110 with windows 2003 server cd
Oct 25, 2007 | HP Compaq ProLiant ML110 G4 Server
HP ProLiant ML110 Server Logo
1,088 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
