Question about Sewing Machines
Can't get the Husqvarna Viking Platinum 775 to do a zig zag
I've tried multiple stitch options & first of all, none of them look like a traditional zig zag to me. Secondly, none of them sew in a zig zag or side-to-side manner. All are making just a straight stitch. Even the options for blind hem & overcast - just straight stitch. Any ideas?
  • Sewing Machines Master
  • 7,365 Answers
It's very possible that a cam or gear has worn down or broken
inside the machine and also if the sewing machine is computerized
then there could be a problem there, having the machine checked
would tell you for sure.
Posted on Nov 08, 2012
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 5 Answers
SOURCE: Sewing Machine Problem
Check to see if the cam stack gear does not have a crack in it. The other problem is the cam engager lever is does not engage the cam stitches because it is gummy. To solve this, lift the lid and follow the lever to where it make contact, add a penetrant oil. More the lever back and forth as fast as you can and work the penetrating oil into the area. It should click back and forth and snap between the back and front V's. One is for the zig zag and straight stitches and the other is for all cam patterns. Once it is clicking and snapping back add regular oil. Thensew out your pattern stitches. If the machine binds then you could have a cracked cam stack gear and has to be change by a Bernina service center.
SewTechnologist
Posted on Apr 21, 2008
  • 201 Answers
SOURCE: Viking Designer 1 won't stitch correctly
Check that twin stitch width safety is not turned on in the SET menu (use More button at bottom of first screen to access third screen).
Posted on Jul 01, 2008
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions drivewithken@blueyonder.co.uk
Posted on May 14, 2009
  • 46 Answers
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
Posted on Jul 27, 2009
I have the settings correct but it still doesn't zig zag correctly??? what could be wrong???
try a new needle
could also be something wrong with the cam that does the zig zag stitch
would be a good idea to have the machine checked to see if there is something wrong with the cam
Mar 09, 2016 | Husqvarna Viking Emerald 116 Sewing...
How to set machine for zig-zag?
What is the model of your machine?
Check user manual. Manuals are available to view, download, or print from husqvarna viking website -
http://www.manuals.husqvarnaviking.com
Jun 18, 2014 | Husqvarna Sewing Machines
Loose underthread and no zig zag
Lower thread tension can be adjusted by tightening (clockwise) the small screw in the bobbin case. The specifications call for 12-20 g resistance when pulling the thread slowly. I suggest tightening in increments of 1/8 turn and trying the machine each time. Also, mark the position of the screw in its original position should you need to return to the original setting and start over (use a piece of tape and place a mark where the slot in the screw is). I don't understand what you're saying about the zig zag problem.
Mar 12, 2014 | Husqvarna Sewing Machines
Viking 6360 buttonhole procedure
you start with the broad zig zag stitch bar across the top
then you go down the left side using a smaller zig zag stitch
then you make the the broad zig zag stitch at the bottom
then you make the smaller zig zag stitch on the right side
all the way to the top broad zig zag stitch & your done
the right side zig zag does not go beyond the top broad zig zag
stitch
Aug 01, 2012 | Husqvarna Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Viking # 1 only sews straight stitch but won't zig-zag
it could also be a worn part, only a sewing machine repair shop can say for sure
Feb 24, 2012 | Husqvarna Viking 1
I need to adjust the needle so when I zig zag it will not hit the plastic. It works perfect on stright stitch.
You might have the zig zag set for z-z left or right-hand. Make sure you are choosing the zig zag centre stitch. Also check you are using the correct foot - it should be the A or B foot with the wide opening.
Apr 06, 2010 | Husqvarna Viking 1
Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
May 23, 2009 | Bernina Virtuosa 150
Looking for Cassette B
I have a B card for the 1100 Viking are you interested?
Jan 28, 2009 | Husqvarna Viking 1
Zig zag stitch & manual Husqvarna 5310
What numbr on the dial of the Husqvarna daisy is the zigzag??
Sep 05, 2008 | Husqvarna Viking 1
Sewing Machines Logo
223 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
