Question about Pool & Spa
My elite spa has three blinking lights on the bottom and the filter and light are blinking
The heater light is blinking once and the filter light is blinking twice and three lights are blinking at the bottom of the control panel
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
  • 5 Answers
SOURCE: PDA quit working and cannot override the system on control panel
I had a problem simmular to yours When I changed my remote I had to also change my antena. Also make sure youd dip switch settings are set the same. between the antena & remote. The only reset that I know of is in the remot. Go to Menu then System Set UP. Then clear Memory. You Will loose all programs like, Dimming relays temp settings times for off & on. etc. I think if you have a intella flo motor you will have to reset it also.
Posted on Oct 05, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
jharwell668
  • 640 Answers
SOURCE: Colorlogic Pool Light flashes like strobe
These swimming pool lights have a power-cycled feature. THis means that you can power down the light and then power back up in 10 seconds and the light pattern will change. It sounds like your light is not cycling properly. Power it down for a full 60 seconds. This will reset the power cycle. Then try turning it on and off in 10 second intervals. If it doesn't reset, you bulb may only be partially functioning and it may need to be replaces.
Posted on Jul 14, 2010
Dream Maker Spa lights BLINKING
possible bad heater element or temp sensor or recirculation pump
Mar 06, 2013 | Dream Maker Spas Pool & Spa
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Leisure bay spa series c, just replaced heat probe refilled spa turned on light is blinking will not go off jets will not come on
What light is blinking? The heater light? Because the heater light will not come on until the spa goes through the purge cycle when the breaker is first turned on.Exactly what is happening once the breaker is turned on
Feb 09, 2011 | Home
Hi, I have an LXi heaterthat keeps kicking off! On
This usually indicates an ignition lockout...The heater tried to fire but either didn't fire or a flame was not detected. Check and ,ake sure ignition is good, gas valve is opening and make sure all grounding is intact..
Jul 30, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
When I turn on my Lennox gas furnace, the blower comes on right away but the heat does not turn on. The ignitor does not turn the pilot on. There is a light that I can see blinking on the front that blinks...
Hi chech the igntior is not cracked or broken see is ga svalve clicks when you turn on , try jumping out pressure switch see if it lights check air filters are clean
Mar 10, 2010 | Heating & Cooling
Power light blinks after blower turns on. Water is barely coming out luke warm after 30m of running. No other status lights lit.
The water is mixed with cool water as it leaves the heater and will only be eight to ten degres hotter than when it goes into the heater so as to avoide scalding. You need to ck the total heat rise of the water after about an hour in a spa and after about three or four hours in a pool.
Nov 21, 2009 | Jandy Laars Lt 400,000 Btu Heater
It will only cycle once and then it shuts off.. i have to turn off and then back on through the thermostat to get it it through another cycle , the system is three years old. i have tried two other...
Your furnace has a diagnostic light in the unit. Look for a small see-thru window either on the top panel or the bottom panel. Look for a blinking light. Record the number of blinks. Now remove the bottom panel and look at the wiring diagram. There will be a error code list explaining what the blinks represent. If you open the panel prior to looking thru the window, you will erase the code. Changing the thermostat is not the solution. Good Luck.
Sep 07, 2009 | Goodman GMS90703BXA Heater
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Pool & Spa Logo
132 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
