Question about Maxent MX-42VM10 42 in. HD-Ready Plasma Television
Picture is squeued vertically from top to bottom.
The picture at the top looks like the sync is lost as the top of picture is distortede.About 1 foot down the picture is solid but a black bar about 4 inches split picture so a part appears on the left of bar and a part on the right of bar
  • lbrijmohan Jan 08, 2009
    I have not removed the board to check yet.
Check for dry joints around the main chassis,esp the supply lines .
Posted on Jan 05, 2009
The top half of the screen is at the bottom...and the bottom half is at the top of the screen...theres a black line through the middle...why is this happening please...
The fault is with its vertical scan output stage circuit. Contact any service technician. This is not a user reparable fault. [Out of Sync: picture].
Gopakumar Gopalan Google
Feb 11, 2014 | Proton MM2701VT 27" TV
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Sharp aqous picture error
You Vertical Problem can you go to advance settings to adjust
vertical Size? Or center the picture
Nov 02, 2012 | Sharp LC Televison & Video
Tv set picture is gone
It depends, the center line you speak of, does it go from side to side? Or top to bottom? Side to side you have problems in the vertical circuit. Top to bottom you have a problem in the horizontal circuit. Not picture tube problem. If it is an analog tv and depending on how old it is. What an estimate and the actual repair would be you are better off buying a new one.
Jan 27, 2009 | Televison & Video
Screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
Apr 25, 2008 | Hitachi 53SDX89B 53" Rear Projection...
Top and bottom of picture missing
farout, bad capacitors in the vertical circuit, you`ll have to get a tv tech out for that repair, lots of them in that circuit and the tech will need the service manual to find them, BMW Rider
Jan 14, 2008 | Televison & Video
1 inch lines on top and bottom of screen
Is the picture overall too small by 1 in. on top and bottom? Or is it cut off by the lines?
If it's too small, look for an adjustment labeled Vertical Height. This may only be accessible internally, it's normally a service adjustment, not a user adjustment.
Your problem is a vertical deflection issue, either an adjustment or the vertical circuit requires repair by a technician. In the latter case, electrolytic capacitors are a likely cause.
Oct 17, 2007 | Televison & Video
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Maxent MX-42VM10 42 in. HD-Ready Plasma Television Logo
562 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
