Question about Maytag MAH2400A Front Load Washer
Series 2000 maytag washer error says F3 E2 - Maytag MAH2400A Front Load Washer
5 Suggested Answers
SOURCE: Maytag Neptune Front Loader - E2 error code
The first time my E2 code came on the washer won't rinse or spin. I checked the drain pump to make sure it was working. (1) Take the back off and pull the two drain lines off pump. Be careful the line going to the drain has a backflow flap, make sure you don't tear it.
(2) On the other side where it drains from the washer to the pump is where I found a bobbie pin that had collected lint and was blocking the drain flow.
When it can't drain the E2 code comes on to let you know it won't rinse or spin.
Make sure to unplug machine before removing back,
Hope this helps everybody with E2 problems.
stude
40stude@bellsouth.net
Posted on Jan 09, 2008
  • 33 Answers
SOURCE: My maytag commercial 2000 series
Verify if the shipping bolts were removed. The machine will be shaking and moving if they weren't. In the back of the machine there should 4 big bolts attached with nuts.
Posted on Mar 14, 2011
  • 57 Answers
SOURCE: Problem with the Maytag Washing Machines maytag
What error are you recieving?
Posted on Jun 17, 2011
jagans504
  • 31 Answers
SOURCE: Maytag series 2000 front load washer poers on but will not run
I am not familiar with this model, but if it has a filter, clean it out. Unplug machine first, and place a catch pan under filter if possible. Have a mop and bucket handy.
Posted on Jun 08, 2012
What do the error codes F3 E2 mean on my Maytag 2000 series front load washing machine?
F3 E2 is an indication of a water temperature sensor (NTC) error, or heating circuit failure. Check the water temperature sensor and check connections to the water temperature sensor.
Several people having this error needed to repair one of the wires to the sensor. - "There were 2 black wires that go to the water temperature sensor. The wires passed through 2 tie wraps that bonded them to a flange off the bottom of the washer drum. They were wrapped with electric tape inside the tie wrap. Prior to joining the bundle of wires that went to the motor, there was one more tie wrap around the 2 black wires. At this tie wrap there was no electric tape to pad between the wires and the tie wraps. One of the wires was nearly severed.
I replaced the wires. Tie wraps should not be used. They are often too tight and crush wires. Especially in a device that inherently has LOTS of motion."
http://www.doityourself.com/forum/electric-large-kitchen-home-appliances/484867-maytag-washer-mhwe201ywoo-error-code-f3-e2.html
Feb 15, 2017 | Maytag Washing Machines
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
When i used my washer after 3-4 mins f3 e2 maytag front load washer , changed ntc but still same
I am sorry to hear that you have error code F3E2. I know how upsetting error codes can be. I see here that for your Maytag washer, error F3E2 means there is a water temperature sensor error. Below is to test the error
WATER TEMPERATURE SENSOR ERROR:
1. If the water temperature sensor valve is out of range (23 degrees to 217 degrees F or -5 to 103 degree C) during the water-heating step of the WASH cycle.
Possible causes/procedures
a. Unplug washer or disconnect power
b. Make sure that connections to water heater and CCU (TH2 & HE2 cavities) connectors are not broken or with wires detached, and that connector internal pins are visible.
c. Check continuity from the water heater sensor (black wires to CCU (TH2 cavity) Connector.
d. If the continuity diagnosis failed, the Main Harness must be replaced.
e. Check the resistance of the heating element.
f. Check the resistance of the water sensor.
g. Plug in the washer or reconnect power.
h. Verify the washer operation by running the Diagnostic test.
i. After the diagnostic test has finished, unplug washer or disconnect power and wait for 15 seconds.
Below is the diagnostic test. I have it in two halves so you can read it best that way.
If you will submit your model number I will be able to help you further.
Nov 25, 2014 | Maytag Washing Machines
F3 E2 error code on my Maytag washing machine
I just had the same problem with my MayTag washing machine - F3 & E2 error codes.
I cleaned out the drain trap then proceeded to remove the top and rear panels to check the Temperature Sensor. The sensor was tested with an Ohms meter and found to be working properly.
I went over the wiring from the Temp Sensor and found that both black wires had been 'cut' under one of the zip ties near the bottom of the washer.
I had to reconnect them with marretts and presto; the washer works perfectly again. If you encounter this same problem - be diligent in going over the wiring. I missed it the first time around.
It's an easy fix for anyone who can strip a wire of the plastic coating.
Good luck :)
Feb 23, 2013 | Maytag MAH6500 Neptune Front Loading...
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What is a F32 error code on a maytag 3000 series
Error Code F3 E2 is a temp system error. This error is displayed if the water temperature sensor value is out of range (23°F to 217°F [-5°C to 103°C]). Correct ohm reading should be 500-100K ?.
Jan 28, 2012 | Maytag Washing Machines
How to change the door switch
Hello.
Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
Related Searches:
F2 Faults
Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
Clear Error Code
If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
Professional Service
The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
Thanks.
Dec 07, 2011 | Washing Machines
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Maytag MAH2400A Front Load Washer Logo
954 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
