Question about Bosch Tools & Hardware - Others
Bosch 1615 EVS plunge router the plunge is stuck how can i free it up
3 Suggested Answers
comax
  • 154 Answers
SOURCE: how to attach 'plunge lock lever' to Bosch 1617
I have been repairing the Bosch tools for quite a few years and I still hate putting those levers on. Unfortunatly,there are no "tricks", you just have to set the spring in the lever then use a small screw driver to set the other end in its slot. Then try to rotate the whole thing untill the lever goes into the proper notch. It usually takes me 5 or 6 times to get it in, sometimes it goes in first time (rare). Sometimes I'm at it for 1/2 an hour.
Good Luck
Posted on Feb 11, 2010
rowdy45176
  • 2176 Answers
SOURCE: Plunge router is stuck in the router base.
If you are talking about the nut tap on it with a hammer, if you are talking about the tubes you can try cleaning them with air and then using some lubricating fluid to free up the piston/springs. Let me know if you need more help
Posted on Mar 16, 2010
Dw621 pulsing speed problem
Try to start it at various speeds. Use contact cleaner on the switch, and the variable speed control resistor.
Mar 02, 2014 | Dewalt DW621 2 HP Evs Plunge Router W/...
I have a Bosch 1617 EVS router, a couple of years old, one of several routers, so not a lot of hours on it. A minute or so after turning it on I get a burning smell. It doesn't smell when I run
Check the armature bearings, especially the lower one hear the collet. It's possible some of the liquid wrench got into the bearing and cleaned out the lubricating grease that's in there. If the bearing is dry or damaged, either from use or during the removal of the stuck collet it will cause the motor to work harder which causes heat buildup and eventually a burning smell. If you bent anything you would feel a very distinct vibration in the tool when you turned it on that wouldn't have been there before. The bigger the bend the greater the vibration.
Sep 19, 2012 | Bosch 1617EVS Router
I have lost user manual for pof 500a router, do you have any info please
Hi pf,
Go to this site and enter your model number and download a free version.
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx#
Handie Andie
Mar 21, 2011 | Bosch Plunge Router
I NEED A 1/2 "
Galaxy appears to have a full assortment of Bosch collets: www.gpcollets.com/bsch_cross.html
(Date added 4/15/11)
Feb 05, 2011 | Bosch 2610997137 Na Deluxe Router Guide...
Plunge router is stuck in the router base. Porter Cabe 891 router is stuck in the plunge base. Released the buckle and won't come out. What to do? Thanks, Joe
Mar 15, 2010 | Porter Cable-Cable 891 2 1/4 Peak HP...
How to attach 'plunge lock lever' to Bosch 1617 EVS router. I had this router replaced because of corrosion, when I opened the case the lever was detached from plunger. Tricky to attach, any suggestions
Good Luck
Oct 24, 2009 | Bosch 1617EVS 2 Router
Milwaukee 5616-29 when turning on, spins up then shuts off.
it sounds like the brushes on your router need to be replaced. It is best to use the milwaukee replacement brushes available from any milwaukee service center.
Oct 02, 2009 | Milwaukee Tool Milwaukee 5616 24 2 ΒΌ Max...
How do you attach a router to a router table/plate
With 3 or 4 flathead screws thru the table into the faceplate of the router.
Sep 14, 2009 | Dewalt 2 Hp Evs Plunge Router
Bosch 1613 vs router, plunge does not stay locked how do I fix it?
It looks like according to the breakdown that there is a hex head bolt under the release lever that when removed can be tightened some to keep it from moving. Before removing anything when you lock it are you putting some pressure on the lock handle. I have one at work that I have to push some on to snug it. If so I would recommend going to Boschtools.com and typing in your exact model number and it will take you to a page where you can look at all the parts involved (about 4) but the operators manual doesn't tell me a thing about agjustments.
May 16, 2009 | Bosch 2610997137 Na Deluxe Router Guide...
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
Tools & Hardware - Others Logo
104 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
