Question about Air Tools & Compressors
Instruction ABAC REDLINE 400/200L LITRE AIR 3HP COMPRESSOR
5 Suggested Answers
  • 1388 Answers
SOURCE: AIR LEAK ON CRAFTSMAN AIR COMPRESSOR, 3HP,25 GAL, HORIZ TANK
The needle valve that you see is the unloader which releases air pressure from the discharge line after set pressure is obtained. If air continues to leak after the compressor shuts off, the check valve installed in the tank is leaking air out of the tank. Follow the air discharge line from the compressor to the tank. There you will find a brass valve which is the check valve. Simple test is to remove the smaller airline (1/4") from the brass valve and check for air leaking. If leaking remove brass valve and check for debris under the white seat. If you cannot clean the valve, replace with generic check valve from www.grainger.com. It will cost less than factory part. Just order the valve considering the fitting sizes that you need. For exact replacement,( www.sears.com parts). If you sears model # begins with WL then your compressor is made by campbell hausfeld and parts may be ordered from www.chpower.com. Good Luck with you repair and email if you have more questions.
Posted on Mar 21, 2009
  • 243 Answers
SOURCE: 3hp, 200 litre, 16cfm clarke compressor running
most types have a valve to start running clear and after switching to delta the valve must close. if there is not such a valve please check the checkvalve. you can try to start with empty tank. when it is ok then, it indicates a dirty checkvalve.
Posted on Feb 07, 2010
SOURCE: Need manual for a Kawasaki model 840703 5gal 3hp
I called 1 800 590-3723 and they are e-mailing a manual to me. For my model (3HP twin tank) they said 10W30 or 5W30.
Posted on Feb 26, 2010
  • 1388 Answers
SOURCE: I have a Central Pneumatic,
If air leaks when motor is off, fault most likely in-tank check valve. Follow discharge air line from pump to tank. Brass/steel valve at tank is the check valve. Remove hose to valve and check for leak. Replace as needed. If air is leaking while motor is running fault could be reed valves in head. Faulty reed valves in head, or torn head gaskets will cause very hot discharge air and tank will most likely never fill to shut off (or take a very long time to fill)
Posted on Sep 07, 2010
I have a craftsman air compressor model number 921.153101 that won't pump-up over 40 pounds
Its probably a oil less compressor so it could be the reed valves are bad or the piston rings are bad.
Feb 01, 2014 | Craftsman Air Tools & Compressors
I have ABAC 270ltrs italian comprosser. after the comprosser reaches its full capacity air starts to leak from its switch. can u pls help me solve this promblem
In 80% of the cases this is the problem. I sulose that you use a lot this compressor so the one way valve gets worn out. The first stel is to pull out the smal hose when the unit stops and see if air escapes. If so then change the black piece in the photo. It will last for a small period of time. I recomend to change the piece in the photo.
This is a way to solve the problem if air escapes trough the small hose.7
Aug 01, 2012 | Craftsman Air Tools & Compressors
I broke the air filter intake need to replace it where can i get one
I need to know the make and model of your air compressor
Aug 17, 2011 | Air Tools & Compressors
Brand new L3 builds to 25 psi then motor goes out on thermal overload.
Honestly if its new I would either return or ask for them to send someone out sounds like check-valve is letting air through witch is loading compressor.
May 06, 2011 | Ingersoll Rand Single Stage Electric...
Air leaks from pressure switch after compressor builds full pressure
if its leaking steady from the unloading valve on the pressure switch after the compressor stops you have a bad check valve!replace it and youl be fine,dont forget to depressurize your tank before!!!!! and use teflon tape on the treads to avoid air leaks when you replace it!
Jan 20, 2011 | Ingersoll Rand Single Stage Electric...
I need to know what size breaker and what size electric cable should be used in the installation of this Ingersoll Rand SS3L3 3hp motor. I've ordered the compressor but it is supposed to take awhile before...
I am assuming that you will be hooking the air compressor to a 240 volt line...
That motor will draw about 18 amps...... so a 20 amp line will be too close to that draw....
so you will be looking at a 30 amp line...
For that you will need to run a 10gauge three wire with ground on a 30 amp two pole breaker...
that will serve you for up to about 100 feet of wire... if you are running the wire farther then that you will need to up size the wire to 8 gauge so that the motor can draw enough to get started...
heatman101
Jan 11, 2011 | Ingersoll Rand Single Stage Electric...
3hp, 200 litre, 16cfm clarke compressor running off 13 amp plug, the fuse keept blowing on start up every now and again but has become constant.
Feb 06, 2010 | Air Tools & Compressors
Jun 19, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
90 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
