Question about Epson AcuLaser C900 Printer
Black Cartridge needs replacement but new cartridge.
Thanks for that. Have sorted problem and got transfer unit installed, but have switched printer back on and now it is telling me that the black catridge needs replacing when I know it is fairly new and nowhere near empty. Could I have damaged a sensor on replacing the transfer unit as red light on top of printer just flashes, with green light steady. If you can help in anyway it would be much appreciated.
  • Anthony Lawrence Jun 05, 2007
    Have taken it to repair shop.
  • Epson Master
  • 705 Answers
Just reset the toner cartridge and the machine will se it a new one. Remeber though it may now actually run out of blsack when the machine thinks it is part full. This will give quality issues when it runs low. If you are not sure on resetting the cart, let me know.
Posted on Jun 11, 2007
  • Inky Fingers
    Inky Fingers Jun 11, 2007
    Sorry for poor spelling, having a twisted fingers day!
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Printer not accepting new black ink cartridge
put that cartridge in and perform a head cleaning process, and allignment... follow the procedure (2 or 3 times if needed) and in the end, shut down the printer, disconnect usb cable (both end), then wait for some time, aprox. 20 sec. and then put both end in again, turn printer on and wait for ready signal or some sort of confirmation that all is ok... If not, replace or update the printer driver and software, or reinstall all printer software.
Apr 22, 2014 | Epson R1900 Printer
We have an HP Color Laserjet 2840 printer in our office. We were low on our black ink drum, bought a new drum and installed it. Copies are coming out perfectly but the "replace black...
The 2840 is a slightly different sort of machine when it comes to supplies. There is a main imaging drum unit which works for all four colors, and then there of course are the 4 colors. If the unit was asking for a drum unit then you should have instaled a Q3964A. It is entirely possible that your drum unit and black cartridge both expired at the same time, in which case, you need a black toner cartridge now.
Jul 28, 2011 | HP LaserJet 2840 All-In-One Printer
Received an error code 50c on my Dell printer
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
Thanks for all the ideas and help ; )
Apr 27, 2010 | Dell A940 All-In-One InkJet Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
HP Lasejet 1200
Seem that it maybe a faulty cartridge. If installing a new cartridge does not sort the problem then there is two other things that could be causing the fault.
1 the transfer roller is out of position.
2 The fuser unit is faulty.
Please try the toner cartridge first though.
Thanks J
Nov 05, 2007 | HP LaserJet 1200 Printer
Epson AcuLaser C900 Printer Logo
184 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
